Why building perspective correction is important.
Discussion in 'Beyond the Basics' started by manaheim, Sep 4, 2008.
  1. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    I'm going to share a little secret here. It's something I use to distinguish a part of my work, so if any of you people come and compete with me on this, I'll send my Uncle Tony out to give you and your camera some lovin'. :lol:
    When we look up at buildings and other vertical structures, our eyes and brains work together to compensate for the odd visual effects that occur. If you stop and pay attention, however, you see that the buildings do not, in fact, appear straight.
    When look at 2d pictures, however, the reality becomes extremely noticable... and yet, for some reason people don't seem to bother trying to fix it. We just accept it as normal and move on.
    HOWEVER, a properly corrected image can have a much greater impact on the viewer. In many cases, the corrected image will feel significantly better to the viewer than the uncorrected one, and they may not even be able to tell you exactly why that is, unless they compare them side by side.
    Now in the past, the process of correction was a manual one and, while not crushingly hard, certainly not terribly easy. Nowadays a company called ePaperPress has a very nice and inexpensive tool called PTLens that greatly simplifies this process. (It still takes some skill and practice, but it's quite managable)
    Here is an example of the results...
    Here is a picture I took before any perspective correction...
    [​IMG]
    And here is the same image AFTER perspective correction...
    [​IMG]
    EDIT: btw, you may notice a TINY angle on the second shot... I've found it works well to leave the tiniest bit of an angle vs. bolt straight, and also keeps you from overdoing it, resulting in an odd Dr. Seuss-y effect.
  2. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
    I'm going to have to try that software. I've been thinking of buying a T/S lens, but this would be alot less expensive!
  3. tirediron
    Jul 8, 2005
    39,314
    11,694
    Victoria, BC
    As usual, this isn't a ten-cent replacement for thousand-dollar tool. Perspective correction software can do a good job (as illustrated above) but there is a price. The image is cropped, the degree of which depends on how severe the correction is. As with so many other software 'solutions' they're good, but not as good as getting it right in the camera. Of course there's a lot to be said for $15 vice $1500+, but...
  4. icassell
    icassell TPF Noob!
    Jun 7, 2008
    9,893
    10
    Arizona
  5. manaheim
    Sep 2, 2005
    14,394
    3,262
    Yeah, I shoot wider than necessary in these situations to ensure I have some extra space to crop without losing the image. I usually lose maybe 5-10% off the sides. Not too bad.
    And yeah... literally $15 instead of even $500 is a pretty significant difference. :)
  6. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    Nice. I'll have to give it a try.
  7. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    If possible rather than point the camera/lens upwards, which is what causes converging verticals, go for a higher shooting position if possible, if not move back, less problem, also wide angle lens will accentuate the effect. H
  8. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    There's a good correction tool in the later versions of Photoshop as well: Filter - Distort - Lens Correction.
    Best,
    Helen
  9. Flash Harry
    Jun 26, 2006
    1,918
    Durham, UK
    You can also use the Spherize thingy in earlier versions for the same effect. H
  10. manaheim
    Sep 2, 2005
    14,394
    3,262
    I'm quite embarrassed to say I didn't know that was there. :lol: It wasn't there before, so it never occurred to me to look for it now. Funny.
    It looks like it doesn't auto correct based upon lens characteristics, though (such as barrel distortion based upon the focal length of the particular lens).
    Still, nice...
  11. Neuner
    Neuner TPF Noob!
    Mar 14, 2007
    314
    In my home.
    Ah, you beat me to it. I've used the grid lines, barrel distortion and vertical/horizontal correction several times. Works really well, but as stated, you do loose some of the picture.
    If the edge of the picture is uniform or relatively easy to match like sky & grass, to save loosing some of the image I've cloned the perimeter to fill in.
  12. manaheim
    Sep 2, 2005
    14,394
    3,262
    Regardless of any of this about what tool you use to do it, I hope the original point isn't lost... this is a GREAT thing to do for pictures of buildings and like objects. (unless of course you're intentionally going for that funky look...)
2d buildings perspective
a simple building perspective
building perspective photo
easy building perspective
perspective building
perspective images building
photos of buildings corrected
why correction is important
