Why is there no noise in a completely black photograph?
carmeyeii
Mexico City
Website
www.flickr.com&
Noise is supposed to be generated, among other circumstances like high ISO speeds, when the camera has gone past its black level. If so, I am confused as to why taking a photograph of complete darkness shows no signs of noise. Is it because the photosites remain virgin? The photo is as black as it gets, and still, is just that a block of pure black, as opposed to a less dark, but still pretty dark, photograph. The blacks on this one are not completely black, nevertheless show a considerable amount of noise, especially the sparkly one. HELP!!:confused:
Hehehe, they sometimes do anyway though.
Anyway, I think there are many reasons why noise is produced. I don't think that the "camera having gone past its black level" is one of them though - so that might explain your test results.
If you take a picture in complete darkness the recorded image will be nothing but noise - possibly very low level noise, but that will be all there is.
What it looks like depends on what happens next. You could make that look pure black (by setting the black level higher than the greatest noise level), dirty grey or even pure white if you wished.
Best,
Helen
That makes sense...
Why is this an issue anyways? digital noise isnt something i would want to produce, generally.
A few theories:
a) Noise is there you're not looking hard enough. As Helen said the image is nothing but noise, however that doesn't mean that the noise covers the entire tonal range. It will still only be in the order of a couple of bits worth of noise under reasonable conditions.
b) Most lossy compression algorithms favour bright red / green channels for information and dump as much data as possible from blue and black areas. This causes huge blockyness when using moderate compression and then after bumping the brightness up. The noise may be eliminated when the file is saved.
c) You may not be able to reproduce it. LCDs are imperfect beasts in a lot of ways, but all screens except top quality IPS panels suffer from lack of graduation in the dark making it often difficult to distinguish near blackness from absolute blackness, and also suffer from branding, sudden jumps in luminance which may mask the 1-2 unit difference in brightness, again most pronounced in the black areas.
d) You may not be picking up noise. Noise is a function of shutter speed, and other inaccuracies. It is reasonable to assume that at ISO100 at 1/1000th of a second you shouldn't really be picking up any noise in the blacks at all.
If no light hits the sensor, then it should not record noise.
Noise isn't caused by light, it just exists in inaccuracies of analogue digital conversion and random currents. Infact a measure of noise in a photodetector (not counting influence of any other circuitry) is called dark current because no light hits the sensor. :)
I hope when your kids ask you one day why the sky is blue you don't reply why is it an issue, you don't want a green sky generally. Where's your sense of discovery, learning and science :p
How about orange? :D
Nice application of logic BTW. :thumbup:
Garbz, great explanation!! Thanks for feeding my "sense of discovery". You've really got it mastered, it seems :) Thanks a lot! :p
