gckless
- Joined
- Dec 22, 2014
- Messages
- 325
- Reaction score
- 72
- Location
- South Korea
- Can others edit my Photos
- Photos OK to edit
I just received one YN560-TX and two YN560-IV's from B&H yesterday. Fresh batteries installed in all devices. Paired both flashes with the TX the exact same way. One flash works fine, fires every time it's commanded and changes power level when the TX is changed. The other flash works intermittently. It will usually flash the blue "RF receive" light whenever it's commanded from the TX, but not always. And even less will it actually perform what it's told. It will only sometimes change power levels, only sometimes fire, seemingly just when it wants to when it receives commands from the TX. This happens no matter the channel or group it's on, even when both flashes are on the same group/channel.
I've already started an RMA with B&H because it really sounds like an internal problem with the flash. But is there something that I can do to avoid sending it back and exchanging? I want a working one and I'm not really hesitant, just want to make sure this wasn't a known bug or something with an easy fix.
