If you go with a Kenko go with their Pro series. The pro series are quite good however their non-pro series are not. I have a 2x non-pro that I do not like or use. I won't even sell it because it so bad. I also have Pro 1.4x that I do like very well and use quite a bit.
As Charlie said you will lose two full stops of light when using a 2x. This means that at the short end of your lens (55mm) you will be at f/9 instead of f/4.5. Most likely you will not be able to autofocus at that aperture since most autofocus systems require f/5.6 or wider. In addition, losing two stops of aperture is going to cost you in either shutter speed (slower) or ISO (higher).
