sabbath999
- Joined
- Apr 11, 2007
- Messages
- 2,701
- Reaction score
- 71
- Location
- Missouri
- Can others edit my Photos
- Photos OK to edit
Ok, I was in Kansas City and I just walked around the zoo once to get some impressions of the 70-200 VR and TC-17E combo.
I shot all the pictures with the tele-converter & lens combo. No great art work here, just a simple walk around the park with me, the camera, the lens & TC, and a SB-600.
I just downloaded the pictures and took a look.
The combo seemed to do fairly well under most circumstances, with the notable exception that it appears to be a BIT soft at the very long end. This isn't really surprising, because the 70-200 also appears to be SLIGHTLY soft at that end as well without the TC when wide open. It does better stopped down a bit, but the point of buying a 2.8 isn't to stop it down.
Honestly, that is pretty disappointing in a $1650 lens... it's not that it is blurry or anything, it is just not tack sharp throughout the entire range... and this lens is supposed to live in the 200mm range. I suppose I can find work-arounds for it but frankly I don't honestly think I should HAVE to find workarounds on a lens in this price range.
All zooms contain compromises, that's a given... and when I say it is not quite tack sharp at 200 I do mean not QUITE... as in not as sharp at 200 as it is at 190... but still pretty sharp.
Also, it may not be the equipment's fault at all, it may be poor shooting technique on my part... the reason I say this is that some images seem quite sharp when shot at 340mm, and some don't... which tells me that I may be at fault. On the picture of the dogs below, the dogs seem soft to me, but the grass in front of them doesn't, especially the stuff sticking up visible in front of the dogs.
Another consideration (in fact, I half suspect it might be the case since these lenses are all calibrated at Nikon before they are shipped) is the UV filter I have on it. It's not a cheapie green box Hoya or anything, but it isn't a B&W or Nikon Clear Glass either. I will do some further testing with it off.
It may also be a case of unrealistic expectations on my part... zooms are not prime lenses... they just aren't.
Anyway, here are a few samples from today. All images are completely unprocessed except for a bit of cropping:
Shot through a black wire cage
340mm (200 x1.7 f/11 1/400) and just a bit soft
340mm (f/10 1/100) doesn't look as soft to me
340mm (f/4.8-wide open 1/125th) shot through obnoxious 2 inch square steel wire caging
You can see a wider sample of the pictures at:
Test Pictures (clicky)
