Were you using just natural light? Was it from a window near your girlfriend's feet? That would explain why the light "dies" (in my opinion) around her head.
Good job :thumbup:
EOS_JD said:Looks a little under exposed to me. A refletor would have helped throw some light back into the shadow areas.
RMThrompson said:A. You're a lucky guy.
B. The photo is good, but I like the idea of more dramatic lighting as well. If this is a lingirie shot, it works well, but purely artistic, I would try to balance the light with something behind her, and use a slightly faster shutter speed to decrease the front light a bit. As noted above, the side lighting can be very dramatic as well, lining the model.
Of course, some of the lighting tricks are to hide flaws in the model (Ive had to use some in my work, see my flickr below), but in this case, I don't think your model HAS any flaws... so your safe no matter what.
It was natural light there was a large window right at her feet. It was kind of a tough situation because we just did this in her bedroom as kind of a spur of the moment thing. I would've like to have a reflector to try a lot of different things with the light.
Also, EOS_JD I'll have to look but I think I might have a shot in the same position that I tried to overexpose a little just to see what would happen I'll have to check it out when I get home.
Adding a reflector will add more detail to the right side of the image. I can see it was natural light and perhaps if she was lying the other way round it would be nicer. you can use a voil curtail to provide a nice diffuser effect on the window.
I'm just starting to experiment with flash and light just now.......So take what I say with a pinch of salt. I'm certainly no master of light!
Cheers
Jim
You can use anything to bounce light in. Tinfoil from your kitchen , a white sheet, anything really![]()
