Aluminum Alloy 5000LM Underwater Photographing Diving Flashlight
Link Delight Online Shop
Official Vendor
Supporting Vendor
Underwater diving flashlight, a kind of high power LED as light source, aviation aluminum alloy or plastic as a tube body materials, dry or high capacity rechargeable lithium batteries to provide energy, super high brightness, super sealing performance, super corrosion resistance, resistance to drop, long life and other characteristics of underwater lighting, is a component of scuba diving (especially night dives) necessary diving equipment.
ARCHON D45 Black Aluminum Alloy 5000LM Underwater Photographing Diving Flashlight
Features: • LED: Five CREE XM-L U2 LED
• Luminous Flux:5000 lumens
• Color temperature: 6500K
• Three output levels, High> Low>Strobe
• Runtime: High: 3.5 hrs, Low: 9 hrs, Strobe: 4 hrs
• Lamp Life: 100000 Hours
• Reflector: Glossy Aluminum reflector, high temperature industrial processes.
• Lens: Explosion proof 8mm Polycarbonate Board
• Angle of light beam 6° hot spot, 50° periphery
• Fluorescence ring and Side light design
• Back pressure sealed system
• Micro - computer chip low voltage warning and protection.
• Strengthened type step-up and step-down voltage constant current drive circuit, high efficiency double mode DC - DC regulator (PWM / PFM) and circuit in case of over-discharge of lithium-ion batteries
• With battery over-discharging protection, polarity reversing protection
• Body is made of imported material of T7075, durable aircraft-grade aluminum alloy and Premium Type III hard-anodized anti-abrasive finish.
What do you think of this waterproof diving flashlight?
[TD="width: 286"][/TD]
It has no damage!It is dustproof and waterproof, diving sports (especially the night dive) necessary diving equipment.
