An Abstraction of Self
It seems from the title that this has a meaning connected to you, but I can't see it.
On reflection, the inclusion of the indefinite article in the title was probably misleading.
To be honest and clear, for a Philistine like myself, the title needs a whole lot more definite words to make a connection with the picture.
Do pictures and titles make any connections ? If this is how Peter sees himself that's fine. It's an abstract after all.
My avatar is how I look on a good day :)
:thumbup: Then I want you as my friend and protector. :D
Hmmm...I thought it was an "abstraction of self" because it's kinda abstract and there's a reflection of what I presume to be the OP in the window. I still don't really "get it" but...yeah.
Bingo! What don't you get?
I guess what I really mean isn't that I don't "get" it, but that it doesn't have a very strong impact on me. For one thing, the reflection is simply not strong enough, as evidenced by the fact that many aren't even seeing it. There's also some other glare and reflection that detracts from the abstract image itself, imo, and that large white screen on the right side that cuts into your reflection just really breaks down the power of the abstract for me. Without the white area, I think the abstract would be much stronger. What if you were to shoot this so that your reflection was over on the left side, in the space between the shorter tubes and the stuff hanging from the top, and then crop that white thing on the right out entirely?
I'll give this a try next time I'm there, probably in a couple of week's time. Just hope they haven't changed the window's contents too much by then!
Trying to make something hugely 'meaningful' about this picture using a mysterious title seems very overblown.
This is your assertion based on your ignorance of what the title refers to. If it helps to throw a little light on the matter at hand in this image, as the hints and clues I've generously supplied you with thus far have found no germ in your mind, another title I considered was A Representation of the Artist as an Expression of Will.
However, this seemed a little long and so I opted for brevity over clarity.
God, this is like pulling teeth!
You can't inject meaning into something with a title.
Firstly: Your assumption that I am trying to make something from nothing by attaching an overblown title is incorrect. The title I have chosen for this piece has a connection to its content; that you (or that others also perhaps) cannot see or make this connection does not alter the fact.
Secondly: To say that the title any piece is given will not affect its meaning is a non sequitur. Even calling something untitled has an effect on how this will be received. Words are arbitrary, titles are not.
