Any one noticed that EXIF data stores a huge amount of information?
yeah the EXIF is astonishing.
I first saw it in Flickr
then an online EXIF thing but gives only pertinant info .. then I saw it in detail.
and all I wanted to do was find out how many shots my refurb'd d600 had. lol
^ wild.
Well i was looking at my Exif data on my one of my shots and i can not believe how much information that it lists.
I never thought to look at it.
This is whats recorded on a single shot on my 1DX
Make
Canon
Model
Canon EOS-1D X
Aperture
5.6
Exposure Time
1/400 (0.0025 sec)
Lens ID
Canon EF 70-200mm f/2.8L IS
Focal Length
185.0 mm
Flash
Off, Did not fire
File Size
6.1 MB
File Type
JPEG
MIME Type
image/jpeg
Image Width
5184
Image Height
3456
Encoding Process
Baseline DCT, Huffman coding
Bits Per Sample
8
Color Components
X Resolution
72
Y Resolution
72
YCbCr Sub Sampling
YCbCr4:2:2 (2 1)
YCbCr Positioning
Co-sited
Exposure Program
Aperture-priority AE
Date and Time (Original)
2014:06:21 07:35:40
Metering Mode
Evaluative
Color Space
sRGB
Custom Rendered
Normal
Exposure Mode
Auto
White Balance
Auto
Scene Capture Type
Standard
Contrast
Normal
Saturation
Normal
Sharpness
6
Quality
Fine
Sequence Number
N/A
F Number
5.6
Exposure Compensation
-1/3
Focus Mode
AI Servo AF
ISO
200
Digital Zoom
None
Compression
JPEG (old-style)
Orientation
Horizontal (normal)
File Name
File Size
6.1 MB
File Modify Date
2014:06:21 20:59:25-04:00
File Permissions
rw-r--r--
File
File Type
JPEG
MIME Type
image/jpeg
Exif Byte Order
Little-endian (Intel, II)
Image Width
5184
Image Height
3456
Encoding Process
Bits Per Sample
8
Color Components
Y Cb Cr Sub Sampling
YCbCr4:2:2 (2 1)
IFD0
Make
Canon
Model
Canon EOS-1D X
Orientation
Horizontal (normal)
X Resolution
72
Y Resolution
72
Resolution Unit
inches
Modify Date
2014:06:21 07:35:40
Artist
Cole Peacock
Y Cb Cr Positioning
Co-sited
Copyright
Florida Keys Photography 2014
Exif IFD
Exposure Time
1/400
F Number
5.6
Exposure Program
ISO
200
Exif _0x8830
Exif _0x8832
200
Exif Version
0230
Date Time Original
2014:06:21 07:35:40
Create Date
2014:06:21 07:35:40
Components Configuration
Y, Cb, Cr, -
Shutter Speed Value
1/395
Aperture Value
5.7
-1/3
Metering Mode
Multi-segment
Flash
Off, Did not fire
Focal Length
185.0 mm
User Comment
N/A
Sub Sec Time
26
Sub Sec Time Original
26
Sub Sec Time Digitized
26
Flashpix Version
0100
Color Space
sRGB
Exif Image Width
5184
Exif Image Height
3456
Focal Plane X Resolution
3545.827633
Focal Plane Y Resolution
3526.530612
Focal Plane Resolution Unit
inches
Custom Rendered
Normal
Exposure Mode
Auto
White Balance
Auto
Scene Capture Type
Standard
Exif _0xa 430
N/A
Exif _0xa 431
072012000140
Exif _0xa 432
70 200 0 0
Exif _0xa 434
EF70-200mm f/2.8L IS USM
Exif _0xa 435
0000000000
Canon
Macro Mode
Normal
Self Timer
Off
Quality
Fine
Canon Flash Mode
Off
Continuous Drive
Continuous, High
Focus Mode
AI Servo AF
Record Mode
JPEG
Canon Image Size
Large
Easy Mode
Manual
Digital Zoom
None
Contrast
Normal
Saturation
Normal
Camera ISO
Auto
Metering Mode
Evaluative
Focus Range
Not Known
Canon Exposure Mode
Lens Type
Long Focal
200 mm
Short Focal
70 mm
Focal Units
1/mm
Max Aperture
2.8
Min Aperture
32
Flash Activity
N/A
Flash Bits
(none)
Zoom Source Width
N/A
Zoom Target Width
N/A
Manual Flash Output
n/a
Color Tone
Normal
Focal Length
185 mm
Focal Plane X Unknown
55538
Focal Plane Y Unknown
20597
Canon Flash Info
0 0 0 0
Auto ISO
100
Base ISO
200
Measured EV
12.38
Target Aperture
5.7
Target Exposure Time
1/406
-1/3
White Balance
Auto
Slow Shutter
None
Sequence Number
N/A
Optical Zoom Code
n/a
Flash Guide Number
N/A
Flash Exposure Comp
N/A
Auto Exposure Bracketing
Off
AEB Bracket Value
N/A
Control Mode
Camera Local Control
F Number
5.7
Exposure Time
1/431
Measured EV2
12.375
Bulb Duration
N/A
Camera Type
EOS High-end
ND Filter
Unknown (-1)
Canon Image Type
Canon EOS-1D X
Canon Firmware Version
Firmware Version 2.0.3
Owner Name
N/A
Canon Model ID
Unknown (0x80000269)
Thumbnail Image Valid Area
0 159 7 112
Canon _0x0019
AF Info Size
530
AF Mode
Unknown (10)
Num AF Points
61
Valid AF Points
61
Canon Image Width
5184
Canon Image Height
3456
AF Image Width
5184
AF Image Height
3456
AF Area Widths
171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171 171
AF Area Heights
169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169 169
AF Area X Positions
259 0 -259 1368 1109 850 575 259 0 -1368 -1109 -850 -575 -259 1368 1109 850 575 259 0 -1368 -1109 -850 -575 -259 1368 1109 850 575 259 0 -1368 -1109 -850 -575 -259 1368 1109 850 575 259 0 -1368 -1109 -850 -575 -259 1368 1109 850 575 259 0 -1368 -1109 -850 -575 -259 259 0 -259
AF Area Y Positions
-584 -584 -584 -390 -390 -390 -390 -390 -390 -390 -390 -390 -390 -390 -193 -193 -193 -193 -193 -193 -193 -193 -193 -193 -193 0 0 0 0 0 0 0 0 0 0 0 193 193 193 193 193 193 193 193 193 193 193 390 390 390 390 390 390 390 390 390 390 390 584 584 584
AF Points In Focus
30
AF Points Selected
18,19,24,29,30,35,40,41,46
Canon _0x0035
16 4294966756 32 60
Bracket Mode
Off
Bracket Value
N/A
Bracket Shot Number
N/A
Raw Jpg Size
Large
WB Bracket Mode
Off
WB Bracket Value AB
N/A
WB Bracket Value GM
N/A
Live View Shooting
Off
Flash Exposure Lock
Off
Lens Model
Internal Serial Number
X041576
Dust Removal Data
(Binary data 1024 bytes)
Canon _0x0098
0 0 0 0
Canon _0x009a
0 5184 3456 0 0
Tone Curve
Standard
Sharpness
6
Sharpness Frequency
n/a
Sensor Red Level
N/A
Sensor Blue Level
N/A
White Balance Red
N/A
White Balance Blue
N/A
Color Temperature
5200
Picture Style
User Def. 3
Digital Gain
N/A
WB Shift AB
N/A
WB Shift GM
N/A
Measured RGGB
887 1024 1024 691
Color Space
sRGB
VRD Offset
N/A
Sensor Width
5344
Sensor Height
3584
Sensor Left Border
144
Sensor Top Border
114
Sensor Right Border
5327
Sensor Bottom Border
3569
Black Mask Left Border
N/A
Black Mask Top Border
N/A
Black Mask Right Border
N/A
Black Mask Bottom Border
N/A
Black Level
129 129 129
Canon _0x4009
0 0 0
Canon _0x4010
N/A
Canon _0x4011
Canon _0x4012
N/A
AF Micro Adj Active
No
AF Micro Adj Value
N/A
Peripheral Lighting
On
Peripheral Lighting Value
66
Original Image Width
5184
Original Image Height
3456
Peripheral Lighting Setting
On
Auto Lighting Optimizer
Off
Canon _0x4019
Canon _0x4021
20 0 0 0 1
Canon _0x4027
20 526087 3903208507 121374208 327945
Canon _0x4028
80 3 0 1 0 1 3 0 0 0 0 0 63 0 0 0 0 0 0 0
Canon Custom
Exposure Level Increments
1/3-stop set, 1/3-stop comp.
ISO Speed Increments
1/3 Stop
AEB Auto Cancel
On
AEB Sequence
0,-,+
AEB Shot Count
7; 0
Spot Meter Link To AF Point
Disable (use center AF point)
Safety Shift
Disable
Usable Shooting Modes
Disable; Flags 0x1e
Usable Metering Modes
Enable; Flags 0xf0
Exposure Mode In Manual
Specified metering mode
Shutter Speed Range
Enable; Hi 1/8192; Lo 1/64
Aperture Range
Enable; Closed 91; Open 1
FE Microadjustment
Disable; 0; 8; 0
AE Microadjustment
Disable; 0; 8; 0
Canon Custom _ Functions2_0x0112
Focusing Screen
Ec-CIV
View Info During Exposure
Disable
LCD Illumination During Bulb
Off
WB Media Image Size Setting
Rear LCD panel
Continuous Shooting Speed
Enable; Hi 12; Lo 3
Continuous Shot Limit
Enable; 99 shots
Canon Custom _ Functions2_0x0612
1 127
Custom Controls
0 0 0 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 255 255 0 3 112 48 0 0 0 0 0 0 0 0 0 0 0 20 80 0 0 0 7 0
Dial Direction Tv Av
Normal
Av Setting Without Lens
Disable
Canon Custom _ Functions2_0x070f
1 6
Lock Microphone Button
Unknown (0 31)
Add Aspect Ratio Info
Off
Timer Length
Enable; 6 s: 6; 16 s: 16; After release: 2
Short Release Time Lag
Disable
Canon Custom _ Functions2_0x0812
N/A
Canon Custom _ Functions2_0x0813
N/A
Interop IFD
Interop Index
R98 - DCF basic file (sRGB)
Interop Version
0100
GPS
GPS Version ID
2.3.0.0
IFD1
Compression
JPEG (old-style)
X Resolution
72
Y Resolution
72
Resolution Unit
inches
Thumbnail Offset
11488
Thumbnail Length
10547
XMP -xmp
N/A
Composite
Aperture
5.6
Drive Mode
Continuous shooting
ISO
200
Image Size
5184x3456
Lens
70.0 - 200.0 mm
Lens ID
Canon EF 70-200mm f/2.8L IS USM
Scale Factor 35efl
Shooting Mode
Shutter Speed
1/400
Sub Sec Create Date
2014:06:21 07:35:40.26
Sub Sec Date Time Original
Sub Sec Modify Date
Thumbnail Image
(Binary data 10547 bytes)
Circle Of Confusion
0.031 mm
FOV
11.5 deg
Focal Length 35efl
185.0 mm (35 mm equivalent: 179.0 mm)
Hyperfocal Distance
196.86 m
Lens 35efl
70.0 - 200.0 mm (35 mm equivalent: 67.7 - 193.6 mm)
Light Value
12.6
Maybe now some of the noobs can see how to spell Canon. ;)
