MACs are no different than other computers. They are not self-calibrating nor do they come pre-calibrated from Apple. They have one advantage: less choice. In this case less choice is good because the displays available from Apple range from mediocre to pretty good. In the wild world of non-proprietary computers the displays range from unusably awful to excellent. (You can put an excellent non-Apple display on a MAC by the way).
There are two processes that you can apply to your display: calibration and profiling. It's important to understand what each does and the limitations of each. Calibration will alter the physical operation of your display. Profiling examines your display's fixed, physical (hopefully calibrated) characteristics and compares that to know standards. This info can be used by software (Photoshop) to help control the presentation of images while you edit.
First an analogy: A sharp knife in the kitchen really makes a difference. You can get your knife professionally sharpened. If your knife is made from the finest Toledo steel it will sharpen to an excellent edge and stay sharp a long time. If your knife came in a set for 19.95 that you brought late-night off the shopping channel and "but wait...you also get" -- well good luck with that.
So, calibrating the cinema display on your MAC Pro gives you a fine-tuned professionally capable work tool. Calibrating the display on your Acer netbook leaves you with the same worthless cr*p you started with. Calibrating a display is ultimately limited by the physical properties of that specific display. Laptop displays for example (MAC included) aren't physically capable of rendering all of the colors in the common color spaces we work with (sRGB & Adobe RGB). Calibrating them doesn't change that. It can still be helpful. I calibrated the display on my Toshiba laptop and it certainly makes photos look better (way too blue before). I still have enough sense not to use it for editing.
Profiling can be real helpful, but it also drives lots of folks nuts. The profile for a display characterizes that display's physical shortcomings and provides that info to Photoshop. Photoshop uses that info and will moderate how it renders a photo to try and compensate for the display. For example; after calibration a specific display still has trouble correctly rendering high value greens. Calibration doesn't fix this shortcoming. This is then discovered when the display is profiled. With this info Photoshop attempts a correction. However if your web browser (IE) is completely profile stupid, you can then load the same photo in Photoshop and in your web browser and see two different photos on your screen simultaneously -- fun fun.
You need a hardware device to calibrate and profile a display. Here's one of the better products:
X-Rite i1Display 2 Professional Monitor Calibration i1 solutions
Just like displays these come in a range of quality/performance.
Joe
