petrochemist179 20
TPF junkie!
- Joined
- Mar 9, 2014
- Messages
- 2,517
- Reaction score
- 2,073
- Location
- North Essex UK
- Can others edit my Photos
- Photos OK to edit
It was only 35-40 years ago that I was routinely shooting with a 50mm on a 35mm SLR. The rule worked reasonably well then - there were no DOF apps, that camera had no DOF preview. Where I needed better accuracy I could make use of the markings on the lens, but that needed measurements rather than just eyeballing.It is indeed false, varying between nearly 1:1 at macro distances and infinity:1 when focusing all the way out. However at moderate distances where portraits are taken its reasonably close. Many years back when i was a beginner, without a DOF preview or rangefinder/measure, I found it useful.No better way to confuse a beginner than to present them with a "rule of thumb" that's false. I've encountered that 1/3 -- 2/3 rule before including long before. I've looked into it carefully and it's bogus.
Joe
For landscapes 1/3 of the way was more of an anglular ratio than a distance one(something that I believe I was told when introduced to the 'rule'). As I started taking closeups I found it no longer applied but an estimated third was a fair compromise for most shots.
A rule of thumb doesn't have to be accurate to be useful. I suspect I still subconsciously use it as a starting point for many shots, making it closer to half way as I get closer in. Things like this only confuse if you treat them as gospel.
As a rule of thumb it's been around a long time. I was presented with it when I was a beginner and that's over 50 years ago. I'm not sure of it's origins but if you spend some time with a DOF simulator you're going to have a hard time finding any kind of general use scenario where it comes close to applying. What would be an example: Put a 50mm lens on a 35mm camera (not too common any more but it was). Go out on a sunny day with some friends and have two friends stand in front of an attraction -- say a fountain. Stop the lens down to f/11 (that's why I said sunny day) and frame your two friends side by side full body with some room to spare. You'll be about 8 or 9 feet away and that's .33 -- .66 DOF distribution.
But for portraits we're going to get closer by hopefully mounting a longer lens. We're not going to use f/11 and very quickly DOF distribution is headed for .49 -- .51. For portraits it's much better to rule of thumb the DOF distribution as 50/50. For landscapes and cityscapes a much better rule of thumb would be to just say most of the DOF will be behind the focus point. Put a 35mm lens on a 35mm camera, stop down to f/8 and shoot a cityscape and 95% of the DOF is behind your focus point.
We've all noted it's an old rule. I used to shoot sheet film and 120 roll film 35 years ago. Landscapes with those bigger formats had less DOF than what I get from a modern smaller format digital camera and a .33 -- .66 distribution may have been more common. Here's another rule of thumb: Almost nobody does that anymore. The progression of technology has been an unrelenting move toward smaller formats and with that comes increased DOF. Portrait photographers make an effort to keep the background blurry. To do that they use larger f/stops and send the DOF distribution straight to 50/50 even with smaller cameras like APS formats. For the rest of us with smaller sensor cameras used "generally" a much more useful rule of thumb is most of the DOF will distribute behind the focus point.
So we're teaching beginners and want to help them with a useful rule of thumb using modern cameras. Rule: Try and focus about 1/3 into your subject for maximized DOF placement. Or rule: Focus on your subject. If you want deep DOF use a small f/stop and if you want shallow DOF use a large f/stop.
My biggest gripe with the 1/3 -- 2/3 rule of thumb is that some beginners try to apply it and that invariably screws them up.
Joe
FWIW 5-10 foot subject distance would have been very common back then.
