- Joined
- Mar 8, 2011
- Messages
- 25,329
- Reaction score
- 9,109
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
And so it begins.
Having mulled it over, I decided to convert a spare bedroom into a dry darkroom. My goal is to have a 'permanent' darkroom set up, but one that can easily be dismantled should the need for the space require it be a bedroom again. So after a bit of planning, measuring and scheming, the project was commenced. I started last night cleaning some of the stuff out, and this morning took the bed apart.
My biggest issue is a window on a south-facing wall, making it light-tight and all. But I didn't want a permanent cover. So I stopped by the local fabric store and picked up some black felt, and a couple 2x2s at Home Depot. I cut the 2x2's to fit snugly in the window opening, holding the black felt up... basically it's all friction-fit. As expected, it doesn't stop all the light,
but I have some old paneling laying around that I will screw to the 2x2s to complete the light trap. The felt is more to seal around the perimeter of the makeshift frame.
Once this is done, I will simply lean the bed up against that part of the wall & window. Then I will start building some simple 2x4/plywood work areas, one to hold the enlarger and another for the various trays. The enlarger will be on the left side of the image, and the trays between it and the corner.
