Best budget lens for landscape photography
Nezumi-kun
I own a Nikon D3100 and I'm quite new to the field of photography. I've been studying how to take nice photos recently. As for lenses, I currently have the 50mm 1.8g and the 18-55mm kit lens.
I'd like to ask what is the best budget lens for landscape photography?
Your 18-55 should do just fine.
But, you need to be as specific as possible, what YOU mean by landscape photography. As it might be different than what I have in mind.
A new lens will not magically make the photos better. It is composition and technique that is the primary factors.
Good lighting conditions, and an interesting subject in front of the lens are as helpful as composition and technique. The 18-55mm lens can do just fine at f/7.1 or f/8. The 50mm is also quite a good single focal length lens; if the picture one desired to be made requires a 50mm lens, then the prime lens ought to do just fine.
Little secret: at f/8, on a 24-MP d-slr, almost any lens is plenty good.
Thank you! I'm currently fond of taking night landscape photos using the kit lens. Will definitely try those settings.
Would it be better if I buy a new lens such as the Tokina 11-18? Or shall I just stick to my current lenses?
Your kit lens should be fine.
The only difference is that the Tokina is wider. But do you NEED the wider angle?
Do you mean the 11-16mm? I can't find an 11-18mm. Either way wider is not necessarily better for landscapes and you'll be wanting to use an aperture of f8-f16 most of the time to prevent depth of field issues so a fast lens is not normally required. What is pretty essential is a decent tripod so you can slow the shutter speed down.
The best budget lens is definatley the kit 18-55mm, at around $50 for a used copy and plenty on the market and the sharpness is acceptable if used in the right conditions.
It's important to think of verticals when you are talking wide and ultrawide lenses, as the further below 50mm you go the more perspective distortion squishes things into the centre of the frame and makes distant objects like buildings or mountains perceptably smaller. For that reason wide and particularly ultrawide lenses occupy a bit of a niche wherethey are great for big foregrounds and big skies, but not so good with anything that has height.
What is it you want to improve over the kit lens?
Night landscapes or astrophotography?
Actually, I'd like to try/do both (if given the chance). Haha. I plan to take my camera for my future hikes specially this upcoming summer.
I'm currently watching youtube videos/ reading articles re: landscape photography. They were mentioning numerous lenses for such use. I honestly have no idea which one do I need specially considering my budget constraints and relative lack of experience in photography. Hehe.
Thank you for all your inputs guys! I appreciate it.
First off i'm going to ramble on here with lots of bad grammar and run on sentences. I apologize for that up front.
As others have suggested above "landscape" can mean different things to different people. I think most people automatically assume "wide angle" lenses are best for landscape and that is true for many situations especially when you want to emphasize the foreground, for example ocean scenes where there is extreme depth of field all the way up to the wet rocks that seem to pop out of the foreground. However if you are a person that thinks of "landscape" as a long panoramic scenes with a grand mountain range then usually wide angle lenses do not work well for that as they push objects farther away to cram more into the frame making the mountains seem small and insignificant. Using a much longer telephoto lens to compress the image and stitching them into a panorama works much better to capture the mountain range as we perceive it with our own eye.
Now if you consider what I said above combined with the knowing that the vast majority of landscapes are shot stopped down to a smaller aperture such as f11-16 for good (but still sharp) depth of field, and that most zoom lenses even of the budget variety (kit lenses) are still acceptably sharp in the middle of the aperture range then generally speaking there are literally TONS of great budget all purpose zoom lenses out there that give you the flexibility to shoot wide or long with good quality. Keep in mind these lenses I am speaking of will probably be variable aperture and not be very suitable for low light situations where a tripod cannot be used. (oh I should mention in case its not obvious. A tripod is a must for landscapes!!)
Now bring the milkway and stars into the mix. Everything I said above you can just through straight out the window, all the rules change. With stars you need to be able to let in as much light as possible for as long as possible without the stars trailing in your exposure. In order to do that you generally need a lens that can shoot with a pretty fast wide open aperture such as 2.8 or better and you need the lens to be wide (especially on a crop sensor camera like your D3100). The wider the lens the longer you can expose without trailing the stars to the point that they become little blobs or streaks.
So to really answer your question, there is no "best" lens. There are always trade offs and sacrifices that must be made for different situations. The fewer sacrifices you make with your lens purchase the exponentially higher the price tag rises. In the world of photography the words best and budget don’t really get along. If you are really serious about landscapes my recommendation is that you will probably want two lenses. I'd start with the Tokina AT-X 116 PRO DX-II 11-16mm f/2.8 as a really good semi flexible wide angle lens good for stars and general wide angle landscape applications. This lens has been noted many times for it capability of capturing great milkyway shots. But for more intimate landscapes and panos i'd recommend something like the Nikon 55-200mm f/4-5.6 VRII. The wide angle Tokina I mentioned can be bought new for about $400 USD and the Nikon zoom for about $150 USD. I'm sure can can find both lenses second hand in great condition for much less.
I should note I'm a Canon/Fuji shooter so hopefully some of the Nikon guys will chime in with there suggestions. I hope some of this was more helpful than confusing. LOL
Since Nikon's will accept any F-Mount lens (within reason) I'd say grab one of the old 35mm Perspective Control lenses. They can be had on any of the decent auction sites for ~$75 and are a blast to use. They do something that no other lenses can.
The 50mm and 30mm 1.8's are some of my favorite nikon lenses including for landscape.
