Church of the Blessed Sacrament/Rio De Janeiro, Brazil
The church is spectacular and you really captured all of the colors
I do like it but it is a bit on the dark side. Maybe as intended though.
Yes it was intended, It was very dark in there.
A little heavy on the reds. Otherwise, I like it.
Jim
Yeah, this.
Excellent image, and I love the vibrant colors. I think you've got the red dialed up a bit too much for my tastes, though.
must be a magnificent place
A little more cooked than I like, but it's very well done, just the same. It's clear you had good control of the process and got the image you wanted. This would have been great in the recently closed HDR thread as an example of "overcooked" that works.
A little less of red on the carpets and it's perfect. I like the light reflection in the middle.
colors ruin it for me. Don't look realistic at the slightest.
That's a bit presumptuous. Perhaps the OP is a Mantis shrimp? I personally suffer from deuteranopia and my world is slightly bleaker.
How is it presumptuous? To assume my eyes are correct in what they are seeing and the information my brain is taking from it? I've spent more than half my life with my eyes opened; that's a lot of data to compare it to.
even if you suffer from color blindness, you can still see normal to you.
Candle light does not glow bright red. sunlight does not glow blue. Incandescent light does not glow green. It not appear appear to look realistic to me. Even if it did, the scene would not be so evenly lit. It looks cartoonish at best to me.
And for an HDR, the blacks seem to be fairly clipped as well.
I also don't like the wide-distortion, the left side appears to be disorted more than the right side. I'd like to see it corrected, or at least evened out. (this is confirmed by measured the angle of the walls on either side of the frame; they don't match)
