- Joined
- Nov 4, 2009
- Messages
- 1,850
- Reaction score
- 7
Do you find sometimes when we taking pictures, your camera is not very stable? When outdoor taking photos it is not convenient to carry camera tripod for us? How to solve the headache problem? Next, let's do a convenient camera stabilizer together!
We do not need complex material, just need a simple PVC pipe, scrap aluminum tubes, and several small screws can easily get.
Materials: PVC plastic pipe, aluminum pipe, screws, nuts, spacer
The above of camera connect screw should set aside enough position, don't close to aluminium alloy pipe.
In selecting PVC pipe, perhaps there is difficult to buy the right PVC pipe in aluminum tube, if it can not buy, you can buy a slightly smaller one, we can reinforce it with spacer, not causing it to shake. Generally can buy from selling the screw store.
Connect the camera screw, most are 1/4 inch, screw pitch is 20 teeth / inch; still have a small part of 3/8 inch, screw pitch is 16 teeth / inch. So the time of purchase, be sure to check your camera. Do not buy the wrong.
1. Perforated for PVC pipe
When selecting the PVC pipe, pay attention to if the PVC diameter is fited with aluminum pipe smallest diameter, we may not be able to find an exact match one, but the more closer the better. Then we use the drill holes that screw can through the hole as appropriate.
2. With the size of aluminum alloy hole
The largest area on both sides of aluminum tubes, the same out of a screw through the hole, pay attention to both sides of the hole to be level. At the top of the aluminum alloy, the same one that allows connection to open the screw holes with the camera.
3. Ring linked
VC pipe on the inside of the aluminum tube, use screws through the aluminum alloy tube outer, again through the PVC tube, until it from the other side, to ensure that the first two steps of the holes hit. Therefore, we must set a good punch on the first two steps of the position.
4. Wear the screws
Total need two screws, one is an ordinary screw, you can get in the building materials market. Another screw suggest you buy on the net, because we know that connect the screw diameter of the camera is not the same. According to your camera to choose the appropriate one!
5. Connect PVC pipe
T-shaped PVC pipe, is composed of four parts, namely the two short tube, a long tube, and a T-shaped connecting tube composed. Two short pipe lengths to ensure uniform, long pipe distance is according to distance from the camera to the chest when using the camera.
6. Finish
First, fix the camera on the aluminum tube, confirm the connection lock nut. Then make the T-type PVC pipe connected to aluminium alloy pipe, also should make sure that the nut lock screw. Thus, the camera stabilizer is done.
3. Ring linked
4. Wear the screws
5. Connect PVC pipe
6. Finish
