That's pretty cool!!! That looks insane! How did you do that?
I will try to remember all the steps taken
Import your original natural image duplicate the layer and uncheck visible the original layer I always do this just in case I need to touch up or go back to step 1
I did a Nik Raw Presharp 43%
Used OnOne photo Tools and added Color Boost Portait preset
then Used Topaz Adjust Psychedelic preset but made some adjustments and under saturated the image
Then duplicated the original layer
Added Nik Color Efex Tonal contrast custom settings applied it
I moved this layer directly underneath the Topaz layer and set the opacity to 60% so both layers are merging.
I then merge down the layers and flatten the image so everything become just 1 layer.
I then used the quick selection tool and went around your friend and the baby and refined the edge
then went to OnOne Phototools PhotoFrame 4.6 and applied one of the frames show above the software renders the image and takes you back to photoshop
I changed the hue of the frame to pink and walla there you have it.
See you said you wanted to know :thumbup:
Total image time 20min
