Digital Camcorders Buying Guide
Link Delight Online Shop
Official Vendor
Supporting Vendor
1. The volume size
You prefer the size of conventional cameras can be placed in a pocket -size or mini, of course, cute can not compare it with other models of convenience, but this advantage is obvious. Select it and you will get a truly portable cameras. But it must be considered that the liquid crystal display of this type is relatively small, generally about 2.5 inches, with a conventional design and the operation of the digital cameras have a different feel. The optical zoom range while smaller models are also relatively small, generally about 10 times to 12 times, compared with a large digital camera 16 times to 22 times optical zoom lens.
2. The price level
Then you should be based on the requirements and the situation of the capital if is abundant, to determine the appropriate price level. In general, the camera is always with VCR, post-production facilities with the composition of a system to use. In the same system, the quality indicators of various devices must be consistent with each other, if you choose the indicators are not consistent with the device, the end result is bound to only reach one of the lowest indicators index funds is so high that it takes on some of the equipment wasted.
3. Select functions
If you are looking for good and absolute quality pictures, then select a 3CCD image sensor (3CCD refer to the camera built into the three primary colors of light sources of red, green, and blue, respectively, after three separate CCD image sensor treatment, to ensure achieve high resolution and color reproduction.) digital video camera. It will provide you with more natural color and a wider visual contrast. And this digital camcorder with 3CCD image sensor volume ratio of a digital image sensor confidential 1CCD only slightly larger. Digital imaging with 500 line level resolution than any other type of models, only high pixel of the CCD image sensors can reach such a high level. Most digital cameras have 800000 to 1 million pixels. But please do not speculate that the higher the pixel will get the higher level of resolution. A majority of the pixels may be lost in the digital image stabilization system startup.
4. The selection of brands
Camera is not a "luxury", the current lowest price of only 700~800 dollars, many large shopping malls, stores have sales. But now the appliance brands are everywhere, we in the end what brand to buy it? I understand that the global sales of digital cameras also reputation of the best is Sony, their products not only product line is very wide, and the quality is relatively strong. In addition to that some other manufacturers, such as Samsung, Philips, etc., they also have similar products in sales. Samsung is one of the more common products on the market, and its good quality and low psoundrice to win the hearts and minds of many consumers. We generally can through the factory stores, medium and large shopping malls to buy camcorders. In the factory store to buy the most convenient and most assured, stores more in-depth understanding of the manufacturers product, accessories are complete, service not only directly, but also and thoughtful. In the medium and large shopping malls to buy the same reassuring its regular purchase channels, and there is the quality of after-sales warranty.
5. After-sales service
Only by established a perfect service system, that can really relieve purchaser those worries. Warranty from date of purchase from the time limit should normally be one year. Maintenance cycle length and distributor maintenance level are releated to manufacturers of spare parts and technical support degree. Some of the distributor to "switch" to ensure the one-year warranty, from the cost may not come true, please confirm to the dealer when you purchase. Select the Genius service system with the best manufacturers is most ideal: buyers can receive timely service, also after the purchase of confidence.
