dslt with 2x converter
cadwr
wales
I've bought a used Jessops 2x converter with autofocus for my sony a33 dslt. On all l enses [ 18-200/75-300/30mm macro] the autofocus hunts & then settles on a point quite a way from correct focus. In manual focus, the converter works & results are sharp, good colour & no chromatic aberation, but of course there is so little depth of field it is a pain to focus manually. Can anyone suggest a fix? { yes I know it's cheap kit at under £50 but the image quality is fine !!!
Cadwr:x
I don't know anything about sony lenses, but I'm assuming those zooms are f5.6 or f6.3 at the long end, I think a 2x teleconverter takes at at least 2 stops away, turning them into f11 lenses, so the camera has a hard time focusing. That's why most people use 2.8 lenses on teleconverters, so to get your £50 teleconverter to autofocus properly you'll need to get a much more expensive lens, or you could just focus manually.
The fix is dont use it your lenses are not good enough to use a 2x converter, most makes will not auto focus after F5.6, i would think your 18-200 is a F5.6 but as soon as you fit the 2X it turns into aN F11 lens
Is the converter affecting the resulting aperture ? AF hunting is sometime caused by not enough light.
There will be no where near enough light because his lowest F stop will be around F8
I guess that's why the sony teleconverters state that they only work with specific lenses...
Well for one no x2 converter is going to AF well and a none Sony knock off will be worse. Save up and get the lens for the focal length you need.
Kenko 2X pro does on my Canon
