eyeglass glare
ffmedic245
East Tennessee
Does any one have any good tips from removing gare off of glasses? I am using abobe photoshop CS3. Any help would be great. Thanks.
I think the best bet is to get in close and use the clone tool to rebuild the detail that is lost. It can be a tricky task, depending on what is lost and what is left to work with.
As with most things, it's better to get it right the first time...so try to avoid it when shooting.
The easiest way I found was to avoid it all together when taking the photograph, which was tricky as I was working with a number of flash heads.
But I gave up trying to remove the glare from the photo's I didn't spot it in.
Not much help i'm afraid :( just remember for next time.
Tell the specs wearer to slightly tilt the glasses down during the shoot, or use a pair with the lenses removed, specs are a nightmare at times. H
