Focal Length - Depth of Field?
EchoingWhisper
Malaysia
I thought: Aperture controls depth of field, then why does focal length control depth of field too?
I used to think that the longer the focal length, the lesser the depth of field, but not anymore.
Since longer focal length compresses the distance between objects, it increases the size of everything further away. Thus, the circle of confusion (bokeh/blur) gets larger too, which makes the background LOOKS more blurry. In reality, the depth of field is just the same, only that the defocused area has larger circle of confusion. The defocused area in shorter focal lengths is not able to be seen because of diffraction/anti aliasing etc.
I might be wrong so, point out any mistakes of my point of view. I don't really understand what I'm talking... lol
Focal length DOES affect DOF. A 20mm lens on an APS camera, focused at 10 feet, at f/4 will have a DOF from 5'-8" to 41'. A 200mm lens with the same settings will have a DOF from 9'-11" to 10'-1"
I think I understand what I am talking about now, if your subject (point of focus) is the same size at all focal length, the depth of field should be the same. Circle of confusion in defocused area of longer focal lengths are larger, but depth of field should be the same.
How does 5'-8" = 9'-11" and 41' = 10'-1"?
If you have the 20mm focused at 10', an object at 20' will be in focus. Switch to a 200mm, and it won't be.
Why, focal length "doesn't matter" is because YOU MOVE. To get the same framing on your subject as you change focal lengths, you move the reciprocal distance.
So the three things that affect DOF, Aperture, Focal Length and Distance to subject, when you frame the subject the same, Focal Length and Distance to subject cancel each other out. ( there actually can be a slight change in DOF but not one that is noticeable.\
The reason a Long lens seems to have a shallower dof is perspective compression
QUOTE=480sparky;2434341]Focal length DOES affect DOF. A 20mm lens on an APS camera, focused at 10 feet, at f/4 will have a DOF from 5'-8" to 41'. A 200mm lens with the same settings will have a DOF from 9'-11" to 10'-1"[/QUOTE]
ONLY if your distance to subject stays constant
Put in your DOF calculator f/4 50mm 10 feet to subject, then put in 100mm 20 feet to subject. DOF will remain the same
Focal length Does affect DOF, But in practice, It doesn't because we move
Yep, that is what I am trying to say.
