Four night shots for C&C
ausemmao
London
Trying out the Gorillapod last night. If the legs were a bit longer, it would be pretty good.
Euston Road by ausemmao, on Flickr
Euston Road Building by ausemmao, on Flickr
Great Portland by ausemmao, on Flickr
Moved a little further away and getting higher up? Something about the composition feels slightly off, perhaps should have been landscape.
Great Portland Street Station by ausemmao, on Flickr
Am i right in thinking that starbursts are pretty much unavoidable for low aperture long exposures with static sources? I'm guessing that a semi transparent filter plus wider aperture is the only way to remove them.
from a technical stance they're fine. you might try taking them at dusk next time
composition wise they're boring
#1 is a good shot. might have been better if you had centered yourself on the sidewalk
Different angles might make the photos more interesting! #2 is for me the better photo. Others are very busy and distracting.
like 1 & 2, 4 is a little busy (was that a bus that went buy?)
Yeah, was a bus. I'd wrapped the gorillapod around the railing without thinking about whether it was actually centered. Observation is something I need to work on, ha. Getting those details is what makes images stand out.
Yep, agreed that they're not as interesting as they could or should be. Was more technical practice than anything. Thanks :)
