Glaucous Gull chipmunk some close up hooded merganser shots and more
ZombiesniperJr
Petawawa Ontario
1 and 2 are a bit underexposed - should be able to see details in the body feathers. I like #4 and 5. The stuffed cheeks made me smile a bit.
WesternGuy
WesternGuy
Thank you it was back lit so that is the reason it is underexposed yeah it made me smile watching the chipmunk stuff its cheeks
WesternGuy
Have you ever thought of using some fill flash in these situations? Just curious.
WesternGuy
WesternGuy
WesternGuy
Dont have a flash on me other then on camera and out there dont want to stress them out
WesternGuy
WesternGuy
Based on my experience shooting "big birds" in Florida, the flash doesn't seem to stress them out. Fill flash is only about 1/1000 of a second, or less, and I have never ever seen a bird react to my flash as generally I dial down the strength of the flash so that it "fills" the shadows to some extent and that is all. I think you will find that a lot of bird photographers use it when required.
WesternGuy
WesternGuy
WesternGuy
WesternGuy
I may try it but not sure i will not use the on camera flash as i dont know how to change the power or even if i can
You are right. I wouldn't waste my time with an "on camera flash". They don't put out enough light and I am not sure if you can even change their strength. You will need a full-fledged flash for proper "fill-in". If you Google "fill flash for bird photography", you will find a lot of stuff to check out, including some YouTube videos.
WesternGuy
