- Joined
- Apr 9, 2009
- Messages
- 41,401
- Reaction score
- 5,706
- Location
- Iowa
- Can others edit my Photos
- Photos OK to edit
Yes, after they were fixed.His links work fine
KmH said:Sorry, since you used Hi 2, noise reduction and some other image processing was indeed done by the camera, without asking you.
Once you go outside the base range of ISO into the ISO Lo or the ISO Hi settings software is used instead of the amplifiers on the image sensor the base ISO range uses.
Both images can be seen at 100%. And I agree that there has been improvement in high iso, that is higher settings. I am talking about the QUALITY at 1600iso.
KmH said:It may not be prudent to assume there is only 1 noise reduction function in the camera.
There are several noise reduction functions I am aware of in Nikon DSLR cameras, and there may be more of them I'm not aware of.
One of the processes performed by the Raw conversion demosaicing algorithm of most Raw converters is a form of noise reduction.
People are saying that technology has advance so fast that you can see a big improvement in high iso hability. The only difference I see is that iso SETTINGS keep getting higher, but quality stays the same.
cgipso1, bellow the picture it says sizes available: small, medium, large, original. click the original version to see it 100%.
jake, that's a good comparison but it shows two different brands and one of them is a full frame. What I get from that comparison is that even if you have 6400iso doesn't mean you should to use it. (unless you have a ff or you don't mind the lower quality). picture quality suffers a lot, either from noise or noise reduction. Kinda like shutter speed hand held, you can shoot at a speed lower than the focal length, doesn't mean it's to be done. (specially without IS). More than likely picture quality would suffer.
check out the d700, it is shocking what I get from that in very low light and high ISO
This is because Nikon sensors have improved more in ISO ability than Canon.
