How unhealthy is flash?
sincere
Berlin
I am currently doing an internship where we are doing lots of product photography. There´s 3 big flashes on a tripod that are being used about 150times an hour(each and in synch) and i am standing about 3-4 feet away from them.
This procedure will go on for the whole next month like this.
Discuss.
I'm sure there is no risk unless you're staring directly into them you could have some eye damage, or if you have a history of epilepsy in your family a seizure could result but it's very unlikely.
As long as you aren't looking directly into the light...I don't know that it would do any damage.
Although I have heard that some people do experience dizziness and\or discomfort when blasted with repeated flash.
The only danger I can think of would be from the UV component in the light from the flash. Studio flashes typically have a relatively long duration, possibly as long as 1/200 sec, though most would be 1/1000 sec or less. Using 1/200 sec as a worst case multiply this by 3 and by 150 times per hour and you get 2.25 secs exposure per hour so I wouldn't worry too much about that. You would pick up more UV exposure just walking around outside for a few seconds.
Having a flash go off close to your eye can be temporarily uncomfortable and possibly disorientating but unless you have a condition such as epilepsy that may be triggered by repeated flashes then I don't think there would be any permanent damage.
Discuss.
You're going to die. Unless you're putting your face on the head nothing is going to happen.
:roll:
Well...as long as you are not at risk of electrical shock (standing in a puddle of water holding the flash)...then I'm sure you'll be fine. Obviously some people are more susceptible to epileptic symptoms/dizziness/etc than others...but you can judge your tolerance and take your time if you need to.
Good luck.
The thing is, its about 25 flashes (where all three go off at the same time) a minute, about every two seconds a flash. This will go on for like a good month like this..
I am one of those, and I also came here to report the fact. I felt queasy, dizzy, a bit sick to the stomach ... and I am sure that if I (personally) were in your situation, sincere, I'd end up with a real and true migraine. The situation that you are in would not do me any good!
By the way, are you coming up north for the meet-up? Have you made up your mind? It is some 6-7 hours (drive/train), but hey, you are in the same country, after all! You should be here!
I think you'd just get a headache. I've experienced repeated flash and it gave me a really bad one.
I don't know how much stock to put in this but I read an article last week about modern society's reliance on artificial light being harmful because exposure to light affects levels of melatonin in the body. Melatonin is responsible for maintaing sleep/wake cycles. That part of the article made sense. But they lost me when they implied a connection between leukemia in children and the use of nightlights. They pointed to studies that concluded that leukemia is almost nonexistant in places where children sleep in natural darkness. It makes me wonder what factors weren't taken into consideration in these particular studies. The doctor who runs the website is a little on the kooky side. Many of his ideas are beyond ridiculous.
Realistically though, I cannot imagine there being any problems. Some people are sensitive to bright lights or flashes of light. Certain forms of epilepsy are the most extreme examples. Other people just get headaches from bright light. I've worn sunglasses religiously for so many years that my eyes are pretty sensitive to bright light. Just knowing the flash is coming is enough to make my eyes water. Just another reason I prefer to be behind the camera and not in front of it. :D
try it, set your flash off a buncha times in a row and see if it bothers you.
The UV exposure topic is an interesting one. Radiation (of all kinds) exposure (as far as I know) is cumulative and you can receive an unhealthy dose all at once (the fraction of a second that the strobe goes off) or over time (like laying in the sun.)
If you are getting an unhealthy amount of UV light your skill will react by producing melatonin. If you start thinkin you are tanning a little, or freckles start showing up or becoming more prominent, then the strobe is having an effect and wearing sunscreen would be a good idea in my non-expert opinion.
My first business was a record label. In 1990, I founded one of the Berlin Techno labels, and proceeded to spend 5+ years every night in trance clubs. What you are describing sounds like strobe lights, but until you add a lot of smoke from a smoke machine (plus cigarettes and joints), extremely-high mega-decibel repetitive techno-bump hard-bass with sub-sine waves, and some chemical recreationals with Red Bull and champagne, consider yourself a noob.
No dicsussion.
If it were possible to receive an unhealthy dose of UV in 'the fraction of a second that the strobe goes off' there would be a lot of very sick photographers and models around.
UV radiation exists just outside one end of the visible light spectrum, which is a form of radiation itself, with infra red just beyond the other end. If the effects of these radiations were cumulative then we would become steadily more sun tanned/burnt through life due to the UV, perceive increasing brightness with our eyes due to the visible light and become steadily warmer due to the IR.
Exposure to excess UV can lead to sunburn and an increase in the likelihood of skin cancer occurring but the amount that you are receiving will be very small. Unless you are either susceptible to flashes triggering a condition such as epilepsy or are finishing work looking as though you have been lying out in direct sun for the whole day you do not have to worry about the effects, they will be no worse than spending a few minutes at most out in the sun.
