It wasn't a planned shoot, so I didn't have time to properly set it up. I grabbed a light and tried to set it up to minimize shadows and didn't have time to set up a back light (which would have mostly taken care of the shadows on the door.) It's also a crop of my kid and her friend. The AF said it was locked on their eyes, so not sure why it's out, unless it was actually focusing on the other girls' eyes. There was alot of red in the photo and the only way I could get it under any kind of control was to desaturate it. Kinda liked it at the time. It does closely match her hair color in real life. Should have had them stand a few more feet out. And yeah, the doors probably weren't the best choice but was the best thing available at the time and looking at the over all pic (which you can't since I didn't post it), worked with the dress colors and everything as a whole, though it doesn't work as good here given the tones are similar to her hair. Live and learn.
First of all these aren't bad, you have a beautiful young lady with an interesting smile. That automatically overrides any perceived errors.
Something isn't right here, if you were shooting at these settings, with flash, either your flash is way under powered or you had it turned down to low. Any chance you were using one of the cheap LED ring lights? They can also cause color issues. Were you on manual, setting your flash with an incident meter or were you on a program mode letting the camera adjust? Learning how to meter for flash is not difficult.
Portraits shot wide open have a certain appeal, but it requires absolutely, positively nailing focus on both eyes. If you're close, with a razor thin DOF, it's impossible to catch both eyes if the head turns either way. Stopping down to f5.6- f8. or better will increase your chance of catching both eyes in focus. Since DOF is a function of distance to subject AND aperture, going to a longer focal length will also increase DOF without stopping down because you have to move further away to fill the frame the same. That's why you see all those expensive 200mm/f2.8 lenses out there.
As to the WB issue there's a couple things. First as I said earlier, if you're using an underpowered LED light you can expect WB issues. Sometimes you can correct it post if you took the time to shoot a target. Second, your camera records "reflected light" . Any light reflected off walls, ceilings, doors, rugs, even objects in the room will cast their respective hues on the subject, especially with a flash. Finally mixing flash with secondary room light causes issues, using a CTO or CTB Gel on the flash and appropriate in camera WB settings can correct the difference between the two.
It's an inexpensive off camera 14" ring light. That was the only light source in the room other than light coming in from another room, but the ring light was closer to them, so I don't think the weak ambient light had much affect. The walls and carpet are pretty neutral tones. We figured the barn doors would make a decent backdrop given the rest of the room. The camera has missed focus before, though I don't think that's the case here (not trying to blame the equipment). I think the focus problem is both girls look like they were standing not perfectly in line with one another, in between what the camera was using as a focus plane and the camera did the best it could. Looking at the overall pic (this was a crop from the larger photo of the two of them), it was clearly focused on the other girl (one of her eyes is very sharp and other soft) and mine was slightly off the focus plane.
The big headache for me was trying to get the color right on this. Given her hair color, red tones in the door, and skin tones, color is hard on this. If I tried to use the eye dropper and select the white of her eye, it gave a weird green cast overall. I tried playing with the reds, yellows and magentas to try to fix the color from the very cool cast that was naturally in the photo but I just wasn't getting anywhere. So pulling down the vibrancy and saturation seemed to do the trick. The door looks about right, her hair is pretty close but the skin tone is still off.
I think the lessons for me are
1. plan out better, though I only had a few minutes and hadn't planned on any of this
2. Take more shots than what I did (this was originally just going to be a social media post of my kid going to formal, but thought I'd use the opportunity for some people practice, something that's not my norm but something I want to explore/expand with.
3. invest in better lighting
4. shoot them individually rather than a group
5. shutter speed & aperture used were more of a compromise than the ideal settings (I was already shooting lower than what I normally do)
like I said, live ad learn... reset the shoot for more DOF. Portraits/studio work isn't my forte and is new to me, so it's a learning experience.
4.Do need to play with the camera and see what it's limits are with multiple targets, as I wonder if it was doing some funky things (it has before but different situation).
