I don't think your camera is holding you back in any way! Get some new glass instead of a new body!
The D300s or D700 would be your choices for high IQ/high ISO bodies, BUT why????? If you're shooting portraits, you want to keep your ISO down. If you need to shoot a portrait at ISO 1600, it means to me that you need to improve your knowledge of lighting (which, as has been alluded to, is progressing). Remember that all light is natural, whether generated by sun, stars, moon, or strobe. A photon is a photon is a photon, and AFAIK, they haven't come up with a way to synthesize them yet.
Why would you rather increase your ISO than add light?
With only two lenses, 18-55mm 3.5-5.6 and 35mm 1.8, I would also seriously look to expanding your lens range as well as your lighting long before considering changing camera bodies.
what do you mean by natural light photography. why not just get a tripod and slow down? are your subjects moving?
I also have the tamron 28-75 2.8. Even with my 1.8 its not enough light sometimes. What lens do you suggest i get? I think the only way is getting a better body...
Well that's the thing. I have a problem in using flash outdoors. It just doesn't look natural and you can tell flash was used. Its also a hassle chasing around kids and adjusting not only the exposure but the flash exposure also. Even TTL doesnt give me any desired results. Plus using the flash will mean I have to either bounce it off something and there is not always *something* I could use. I could use a reflector but its just too much equipment and I don't have an assistant. With outdoor shoots id like to shoot right on the go, and not have to "stage" every shot.
Anyways ive been through this guys site http://www.neilvn.com and he uses flash outdoors. His photos are amazing and natural looking, so im reading a lot of his articles. I also want to sign up for one of his workshop. But anyways he also uses a high ISO (800-1600) for his low light portraits and they look crystal clear. Does he have an anti noise software or something, or is it his camera that can handle it?
Cuz learning to use flash is hard.
Wait.. so some of you said the D5100 and the D7000 have the same sensor?? I was thinking of getting the d7000 but if the d5100 is the equivalent ill just get that!
Shooting portraits outside without a flash or reflector is going to make your shots look like every other beginner, not very interesting, if flash is used well outside you can hardly tell
I respectfully disagree with your disagreement.I respectfully disagree gary.
I respectfully disagree gary. Sometimes the light is just right (diffused sun form behind you and blue sky behind the subject) and I rather shoot without flash.
