Gavjenks
- Joined
- May 9, 2013
- Messages
- 2,976
- Reaction score
- 588
- Location
- Iowa City, IA
- Can others edit my Photos
- Photos OK to edit
We all usually do visible light photography, and films and sensors can be made sensitive to infrared and ultraviolet fairly easily.
What about the other parts of the spectrum?
-Radio
-Microwave
-X-ray
-Gamma ray
I realize there are significant obstacles to all of these, but that doesn't mean it isn't possible to make everyday images using them.
Basically, what you need to detect a photon of light is a molecule that has some sort of transitional change it can make that very closely matches in energy required to the amount of energy that a photon of a given wavelength can provide. Transitions can be lots of things: ionizations, rotations, breaking or forming bonds between chemicals by providing enough initial energy, vibrations, changes in the energy levels of electrons, etc. Visible light is so easily detectable, because it has an amount of energy that corresponds conveniently to a wide variety of such possible transition modes. Low frequency light like radio waves is harder to detect, because it has very low energy and can't cause big enough changes to be very conveniently detectable. Gamma rays are hard to detect, because they have too MUCH energy to match with most convenient transitions. But inconvenient does not mean impossible...
Radio and microwaves:
These have low energy. They still have enough to excite loose electrons in a large enough piece of conductive material (like an antenna), and they have enough energy also to induce vibrations in some weak chemical bonds or relationships (like your microwave oven vibrating and thus heating up hydrogen bonds between water, or easily spinnable bonds in chains of fat).
Photographs could presumably be made by arrays of antennas (most likely sweeping across a very large format area as a scanning-type sensor, due to cost and space). Photographs could also possibly be made by measuring heating patterns of materials susceptible to vibration, and transducing that into electricity. Or, if you could find a piezoelectric material that vibrates from microwaves or radio, it is automatically transduced into electricity.
The antenna thing might not work in an array, because the fields from multiple antennae would interfere with one another. But if the interference could be "decoded" that might not be a problem. Or you could just scan for even longer with one antenna (imagine a dish and antenna panning across a 2-dimensional space of a couple of meters or so, each couple of milliseconds dumping its output as a "pixel")
X-rays and gamma rays:
These are too high energy to react directly in useful quantities with typical photographic compounds. However, you can use fluorescent intensifying screens. These use the process of fluorescence to absorb higher energy x rays, and output lower energy visible light. Basically, materials are chosen for a certain range of wavelengths such that one photon of light has just the right amount of energy to excite 2 electrons in the fluorescent material (or 2 excites 5 or whatever). Then each of those electrons calms down and emits light of only half (or 2/5 or whatever) the original energy, thus converting to visible light, which is easier to record. The visible light film is exposed in contact with the screen.
Normally, in a medical situation, you create a bunch of x rays, fire them at a patient, and then record the ones that get through. So you're creating your own (dangerous) light source. But can you do the same to photograph background radiation? It might take a few hours, and you might want to be at a high altitude to get a shorter exposure, but it should still work.
Or is there some reason this isn't possible?
Ionization is also a possible method that might be employed to record images from high energy photons like x ray and gamma rays. A screen of ionizable material at the desired wavelengths could record only sufficiently energetic light, and then some method could be used to record the subsequent radioactive decay from the newly made ions into electricity. Or the ions could chemically react with something to form a more stable image on analog film, to be developed later.
-Radio
-Microwave
-X-ray
-Gamma ray
