Laptop woes
Kendall9991
United States
Hoping someone here is familiar with pc's.
I completely Restored it so I could start from scratch. Below is just a copy of what I sent to ASUS support. It is an ASUS X54C laptop running Windows 7 64-bit.
I performed a complete restore of the system and everything has worked great except I can not connect to wifi now. It worked before the restore so I know it has an internal wifi adapter.
It does not have any option for it anywhere. I have tried installing all 4 different drivers off of your website with no luck. I am not sure were to go from here now however.
Under device managers, the only one listed under "Network adapters" is "Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20)"
Underneath "Other devices" the only thing displayed is "Network Controller" which has a yellow triangle with an exclamation mark in it.
When I tried installing the drivers, it said that the network adapter was either removed or ejected. Windows can also not find a driver for this.
Worst case scenario, you could get a little USB adapter. I have one on my PC and it works fine.
Make sure to add the following disclaimer to your post:
Please do not suggest I start buying Apple computers.
