- Joined
- Mar 29, 2016
- Messages
- 16,208
- Reaction score
- 9,658
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #1
Looking for advice on a lighting setup for a shot I want to try. This will be a low key image, with a black background. Subject setting on a black felt stage, holding a lighted object out in front of them, that is giving the appearance of casting light onto the subject face and body. I know I can create the effect post, (I've done it before) but that isn't the point of this learning experience. The lighted object will be an incandescent light (not overly bright). I also know I likely will need gels on the lights to even out the mixed lighting. So here's the setup I'm thinking.
The red dot in front of the subject represents the lighted object. Camera left, is a 2x4 diffused gridded, softbox for fill on the shadow side, flagged. Camera right front is a diffused 7", 40 degree gridded strobe, flagged to keep light off the object. Camera right rear is 7" reflector with 10 degree grid, high kicker. The lighting locations are approximate, and not meant to represent the absolute final placement, but rather a general idea of location.
Another option I thought about was a large Black V flat with a hole to poke the lens through that might do a better job keeping the light off the lighted object. Any comments or suggestions as I start this journey?
