Jack2013
- Joined
- Oct 16, 2013
- Messages
- 48
- Reaction score
- 3
- Location
- United Kingdom
- Can others edit my Photos
- Photos NOT OK to edit
Hi all,
I've noticed a possible design flaw and wondered whether it was indeed a flaw or if there is a 'workaround'.
When attaching a tripod to the 400AW (the bag I own but perhaps the same for other flipsides) the tripod extends below the bottom of the bag. This wouldn't be a problem if space wasn't an issue but on public transport space often is! With the tripod extended below the bottom of the bag the bag often has it's full weight on the tripod (with the bag stood upright).
This causes a bit of an issue as most tripods have a load rating..
Anyone have/had this problem and found a workaround?
Cheers
Jack
Cheers
Jack
Seriously though, it shouldn't be an issue. I'm curious though, doesn't it have a pocket that holds the tripod feet? I don't have a flipside but I have two other LowePro bags and there is normally a pouch that either attaches or flips out and holds two of the tripod feet. I take the third leg and swing it out, then lean the whole set up over so it stands on it's own.
The guys at DigitalRev did a cheap tripod video where they folded up the legs of a table on one end and used a tripod instead; then sat on the table. IIRC some tripods slipped, and some disintegrated. :shock:
