adamhiram
- Joined
- Feb 6, 2015
- Messages
- 870
- Reaction score
- 588
- Can others edit my Photos
- Photos OK to edit
It has been a few years since I updated my formal headshot, so I figured it was time to take a new one. I configured the lighting and setup the shot myself, but asked another photographer to press the shutter to ensure I was in sharp focus. I reused the lighting setup from this school photo shoot, but swapped the painted canvas backdrop for gray seamless paper, and used a single light positioned behind the subject to create a grid spot. I took shots both with and without glasses to give some options, as well as give me some eyes to composite into the shot with glasses if needed to correct for glare, although that wasn't necessary here.
Lighting setup
Nikon Z6II with 85mm f/1.8 lens
85mm, f/8, 1/200s
20211010-DSC_4330a-8x10 by adamhiram, on Flickr
20211010-DSC_4336a-8x10 by adamhiram, on Flickr
Lighting setup
- Key: I used a 38” octobox (technically a dodecabox) somewhere between loop and Rembrandt lighting. My goal was to shape the face withe a significant amount of shadow, and create a pleasing single catchlight.
- Fill: My go-to modifier for fill is a 42” white reflector, moved close enough to give a 2:1 key/fill ratio. I find that a white reflector is a great way to brighten shadow detail without adding a noticeable 2nd catchlight in the eyes, as you would see with a silver reflector or separate light source.
- Background: I positioned a strobe behind the subject with a 7" reflector and 20° grid to create a central grid spot on the background. The backdrop is a roll of seamless paper in Fashion Gray. I had an 86" wide roll setup, although I would typically use the more convenient 53" roll for such a tight shot
85mm, f/8, 1/200s
