New Tetenal InkJet paper
fred
I recently tried a German inkjet paper call Tetenal. The quality is really amazing. The Duo print is a matte finish distinguished by very high grade whites. The double-sided coating supports all common resolutions up to 2880 dpi ensuring a high brilliance and dot sharpness. The price is even more unbelievable, I found it at ImageProInternational.com for $8.50 for 100 sheets at http://www.imageprointernational.com/shopexd.asp?id=795
Another excellent paper is their Photo Semi Matte 240g in 24" x 65' (61.0 cm x 20 m)
with a satin/gloss surface that gives a high quality portraits and proofs. The paper is suitable for use in a wide range of commonly used inkjet printers up to 5760 dpi, is barrier-coated and rapid drying.
With its special surface it is perfect for the rendering of high grade portraits as well as proofs. This paper with its impressive high weight, short drying times and satin gloss surface, is suitable for use in a wide range of commonly used print systems like my Epson 7600.
have a look at: http://www.imageprointernational.com/shopexd.asp?id=791, the price is also excellent at $66.50
