cgipson1
- Joined
- Aug 18, 2011
- Messages
- 17,142
- Reaction score
- 4,350
- Can others edit my Photos
- Photos NOT OK to edit
That's really interesting.
I read the opposite. Multiple discussions online where people are recommending the 35mm over the 50mm due to more versatility.
I had the 35 1.8 for about a week... used it, and gave it away! It was a waste of $200! (well, not a total waste, as I gave it to my GF.. she isn't very picky!)
I would suggest as mentioned... keep your shutter speed higher if handheld... or tripod it (or raise the ISO a couple of stops. While I really dislike that lens.. it isn't as bad as you describe in your OP.
Which one would you recommend instead? I would like to stay below $400.
That lens would probably work for you, if you just keep the shutter speed up.. or use flash in really low light conditions. That 35? A lot of people really like it... I found the AF inconsistent, and unacceptably soft on the edges. You may not have that problem! Test it... on a tripod, with flash. That will give you the sharpest test images. Then decide whether you want to keep it.
I would recommend a Nikon 50 1.8 unless you are set on the WA. Even the Sigma 50 1.4 rocks, as long as you get a good copy.
