Photography Equipments-40m waterproof housing for p7100 & cylinder photography fan
Link Delight Online Shop
Official Vendor
Supporting Vendor
As an online store for Photographers or other electronics customers, amount of photography equipments and customer electronics will be in stock from Linkdelight. According to manufactures, repair shops or insurers, the most common reasons for digital cameras breakage are taking photos underwater. This underwater camera housing for p7100 allows your Nikon P7100 camera shooting underwater down to 40 meters (130 feet) to discover the world of the underwater. With this special design case, every key of inside Nikon P7100 can be pressed to control freely as you want.
Features:
Polycarbonate Construction, durable and resistance to corrosion
Clear view the camera information and control function
"O" ring sealed with spring-loaded
1/4″ tripod screw on the bottom
Ideal for diving, surfing, snorkeling, skiing, yacht or other activities
Suitable for rain, snow, dusty or muddy environment
Coming with lubricant grease and rubber band
Kindly Note:
I: Before close the case, pls coat around the joint with the lubricant grease to get the good sealing effect.
II: Shoot under sea; before put in to the sea, pls put this case in fresh water to make sure the case is completely sealed
III: After shoot under sea, pls rinse out the seawater with the fresh water to avoid the seawater erode the case
SF-01 studio fan is a professional product, which is most suitable for shooting of dancing wedding dress, durative stage smoke effect and blowing sand scene in studio. Being equipped with output speed controller, the 130w photography fan is benefits users a free control on weak or strong wind. With cylinder shaped metal casting, integrated of metal blower blade and motor, support users' compact structure.
Features:
Remote operation -- 3m adjustment and control cable and 5m power cord enable you a remote operation;
Stepless force -- The blower is equipped with wind force control benefiting you a free control on weak and strong force of wind;
High configuration -- Internationally advanced power frequency axial fan, flange installation, reliable connection;
Professional design -- Cylinder type metal casing, integration of metal fan blade with motor benefit a compact structure.
