Photos - Wrong Aspect Ratio ??
craige4u
I have clicked around 300 photos and all turned out to be normal as intended except few every now & then (9 photos) where the subject tht is standing is appearing to be compressed, i.e, wrong aspect ratio... whereas background seems perfectly normal... I have no clue how this can happen....
Pls provide your input..... Also if it can corrected in Photoshop CS6
I'm sorry but I don't understand. I'm sure someone else will have better luck.
Well.... I wont be able to post pics due to privacy concerns...
I will give an example: Take a spring in your thumb & finger and press it down... The pics are appearing as such, if you get the idea!
Try adjusting the aspect ratio?
If its 5:1 and it should be 3:2, simply change it and see if it reverts back to normal?
