50+ views and no comments or criticisms? Either it's a perfectly average picture or nobody has any opinion...
There is too much grain in this picture. It seems like you pulled the curves/levels too far and started introducing noise and attempted to sharpen it? The skins tons seems a little too blown out. As they said the card on the cabinet becomes too much of a focal point...especially where it is currently positioned. Are you sure this was with f2.8? Maybe the subject should have stepped away from the cabinets a little further? Your shirt is a little bit distracting in contrast. Black with white design + blown out face of the girl looks like you have three heads laying on your chest. Hard to find focus except for the white card at the corner.
If you still have the original picture, I would try not pushing your curves/levels too high. If you didn't take this raw, you've lost a lot of data due to compression so you're limited to how much you can push the exposure of the picture.
So instead I would try to blur out the background as suggested...that card is going to be difficult to work with, but perhaps stamp the cabinet and hopefully the blur will help with concealing the stamping process.
Touch up the skin tones so there isn't a lot of noise and give it a softer look.
Bring your dark/grey tones out a little more to tone down on the over exposure.
As far as the shirt goes, I would try adding a gradient from the lower left till near the girl's face to grey out the design a little bit.
Try to give it a soft focus look, this might help in making the blown out areas seem intentional for a dreamy look?
Finally add a vignette to bring focus back to the subjects.
Hope this helps.
Good luck.
PJ
