Prime vs zoom vs single focal length.
Early
Western NJ
Please correct me if I'm wrong and confused, but I'd like to clear this up.
A lot of people are calling a 50 mm f1/8 a prime lens, and zoom lenses non primes when the opposite could be true. It is my understanding that a prime lense is a manufacturer’s premium lens, be it a zoom or single focal length. Like Nikon’s 28-70mm f2.8D would be a prime lens as would the 200 mm f2 because of the build quality. Where as, a 50mm f1.8 is not considered a prime since it is usually cheaply made.
Commonly, the term "prime" is used to mean "single focal length" and a "non-prime" is a "zoom." I'm not defending that position but merely stating what I've heard.
There's no "western NJ." The state isn't wide enough for an eastern portion and a western portion!
You are indeed a tad confused. A prime lens refers to one with a fixed focal length, ie: 50mm, 85mm, 135mm, 200mm, etc... and has nothing to do whatsoever with the image or build quality. A zoom lens covers a range of focal lengths.
Every company has its own terminology for their high end lenses. Canon calls them "L" lenses. Sigma I believe uses the "EX" designation. Nikon has its own as well.
What is the Nikon designation for premium lenses?
"Prime lens" nowdays means fixed focal length. It used to mean the main lens in a system if lenses i believe, as in "primary" lens. The term doesn't carry any connotations of quality. Prime lenses are usually sharper and faster than zooms and prefered over them in many cases, so you might get that impression.
It's just a term...different people use it in different ways.
As the others have mentioned, it usually refers to 'fixed focal length lenses' as opposed to 'variable focal length lenses' (zoom lenses).
I have heard people use it to describe the lens that they personally use the most (it's their prime lens)...in which case, it might be a zoom or a fixed focal length.
Any respectable photographer wouldn't use the term like that, would they? That just causes confusion.
"Bagboy, get my Prime lens out of the bag, please. No, I don't actually want a prime lens, I want my GOOD lens!"
Oi!
Well, if that photographer has been around since before all these people started using 'Prime' for non zoom lenses...then I wouldn't blame them.
Q: "What lens do you use to shoot portraits?"
A: "I Primarily use a 100mm."
Q: "What lens to you use to shoot a wedding?"
A: "I Primarily use a 24-70mm."
Well considering in the old days most cameras didnt have zoom lenses available. I dont think I had a single zoom till the 70s'. And the late 70s' at that.
Some of the earliest zoom lenses, including the 1958 Pan-Cinor for example, consisted of a prime lens and a zoom unit. The term 'prime lens' was then, and still is, used to describe the main lens in a combination of lenses (as mentioned by Tasmaster). In the Pan-Cinor the prime lens fitted both descriptions: it had a fixed focal length, and it was the main lens.
Best,
Helen
If there is a east and west orange in NJ, then surely there could be a east and west NJ no? ;)
Hmmm...
Desperately trying to think of a snappy retort and not having any luck.
I always understood a Prime lens to be one that just has one focal length. Ive also seen them called "standard" (like this 50mm I just got is called a standard)
Just whats Ive heard, tho. Thats how I always use it at least.
Standard, or "normal" typically refers to a 50mm lens exclusively (when dealin with most DSLRS and 35mm cameras), because the 50mm lens approximates the field of view and perspective of the human eye.
It has a focal length approximately equal to the diagonal of the film format with which it is used (e.g. 50mm with 35mm cameras).
