push/pull for overexposed film
rbailey23
I accidentally shot a roll of triX B/W 400 at 200 ASA. Since overexposed shots come out brighter, I would think it would be better to develop the film LONGER, since that makes them darker/ higher contrast. But most sites tell you to do the opposite, and I don't understand why.
You develope them for less time thats how pulling works
Overexposing negative film means that the image on the film will be darker, not lighter (it will only look lighter after it is reversed during printing). Therefore you want to develop less, to reduce the amount the film darkens in the developer.
It is the same for regular reversal (slide) film, because that is first developed to a negative.
Hi and welcome here. Do not wonder, your thinking is pure digital and film has nothing to do with that technology. It operates on different principles based on real light absorption and if your film absorbed too much the only way to mitigate it is to reduce the development and not to use all of that absorbed light and get the negative in proper optical densities. Over exposure is done routinely by photographers seeking reach and less contrasty negatives.
Here's what is going on with film...
The emulsion of the film (the light sensitive part) is made of silver halide crystals. Silver halide changes when exposed to light, the more light, the more change. It is the developing process that completes the change of the crystals, and the 'fixing' process that removes all the unexposed crystals, leaving you with a photo negative. There is latitude, range, in all of this process. Time is a factor, so developing time is going to change the halides more or less depending on how long the time is.
So, film that has been overexposed, in your case one stop, is going to look more and more overexposed the longer the development time goes. Those halides that were hammered by light will just continue to cook and cook and cook with longer development. On the other extreme, if you used an ridiculously short development time, like 30 seconds, you would end up with film that would look grossly underexposed, despite the fact that the exposure is +1.
The famous Zone System of exposure has a basic rule that you 'overexpose and under-develop'. This gives you shadow detail and un-blown highlights.
So if you are going to develop that film, do the time/temp calculations to develop it minus 1, that should give you film that is like it was exposed at 400.
how can I rate the development down a step? I typically do 9:45 in d-76 1:1 ratio
btw i do not own a digital camera and it is not "digital thinking" .
yikes, if i'm reading the massive chart correctly, it looks like the only difference between developing at 400 iso and stopping down to 200 is 15 seconds. That means i would be clocking at 9:30 instead of 9:45. that's hardly a difference at all.
When you set your camera to a low ISO, you are telling the camera, "this film is not very sensitive to light," so your camera gives it more exposure. Then, since it got more exposure, it will need less development to bring out the image.
After doing a little reading I am realizing that the pull process will cause the photo to lose contrast. I wonder if I would be better off pulling the film and using a higher contrast filter in the enlarger? or just developing the film normally and using a lower contrast filter....? note that i was shooting in clear daylight.
As I said before, shorten the development just by a little, if you don't your highlights might be hard to print (they will be dens). You will not loose too much of a contrast, maybe half a filter value. You may also use more contrasty paper developer or add for that occasion 1/2 g of potassium bromide to your regular one. You may also try compensating development. Over exposing TX by one stop is not such a big deal thanks to its large latitude.
The Massive Dev Chart is usually a good starting point, but it's not the bible. The times listed there may not be to your liking.
I push much more often than pull, but a 15 second change in dev time sounds pretty insignificant to me...
Personally (this is totally just a guess - I would do a test roll before trying to develop anything important), if your normal time was 9:45, I would try something like 8 minutes.
What developer are you going to use?
You are only 1 stop off on correct exposure. The latitude of the film will not be a problem at only 1 stop. You will have minimal problems at normal development times. There is that much variation many times within a single photograph. Cut a few seconds off development time and you should be safe.
