Rookie Photographer
tjsphotos
AKLD , NZ
You've posted way to many photos for specific C&C, and made it difficult to refer to any single photo because you didn't number them.
Most of the photos are badly under exposed (to dark).
The watermark is obnoxious.
The 2 bright ones were made using the wrong white balance which is why they have such a strong yellow cast.
Here are some subjects you could benefit from studying: Digital Photography Tutorials
Lose the watermark, or put it somewhere less obtrusive for starters. No one here or anywhere, likely, is going to steal your photos. Pick 3 or 4 that you want help with, and post them again. KmH hit the nail on the head for what it's worth.
The guy's that own and drive those race cars will copy those photos in a heart beat.
Of course it's doubtful any of them will know about TPF.
True enough
the angle is a bit bland and i think the logo is poorly placed. i would try spending some time and designing an actual word mark and using it as your logo
How much you want to bet the OP knows little, if anything, about graphic design. If they did, they wouldn't need as much hjelp with their photography since graphic design is also a visual art.
"Photos" is the plural of "photo".
"Photo's" is the possessive form of "photo".
EX: That photo's color is very pleasing.
EX: Those photos are pretty.
Your watermark is lame anyway.
i just put the watermark on for fb use as these are being sold to anyone the orders them . as i didnt have the photo's on my laptop at time of being put up due to my laptop was getting repaired they had to restore to factory settting so lost of all work on here so i have backed them up havent put back on here yet so on imageshack i used links to the photo file on fb to post them
here is another 4 photos with watermarked in them
By tjgamer at 2011-08-13
Your on-camera-flash is making these images flat. If you are with someone, you could get that flash off the camera and have them set up somewhere else on the track to create much more interesting images. If you don't have this gear, you're quite limited to what you can do to improve.
The three shots in the first set you have that are ambient lit are much more 'real' and intense although the color balance is wrong. They show motion blur which gives me a sense that these machines are actually moving and maneuvering quickly. You did a pretty job panning with them too. I'd say don't use the flash at all unless you want to try some 2nd curtain flash with an off-camera light. And fix that white balance.
Was using a canon Speedlite 430ex with the stock stand lens at the time i will be getting a better lens hopefully before season here starts again .
the frist photo it the 4
c
amera used:
Orientation:
Focal length:
Aperture:
Date/Time:
Exposure time:
Lens F-Number:
ISO:
Whitebalance:
Metering mode:
[TD="class: image-details-value"]Canon Canon EOS 550D[/TD]
[TD="class: image-details-value"]Horizontal (normal)[/TD]
[TD="class: image-details-value"]90.0 mm (35 mm equivalent: 141.5 mm)[/TD]
[TD="class: image-details-value"]f/4.5[/TD]
[TD="class: image-details-value"]2011-04-02 21:06:07.00[/TD]
[TD="class: image-details-value"]1/125[/TD]
[TD="class: image-details-value"]400[/TD]
[TD="class: image-details-value"]Auto[/TD]
[TD="class: image-details-value"]Evaluative[/TD]
the second in the 4
Camera used:
Orientation:
Focal length:
Aperture:
Date/Time:
Exposure time:
Lens F-Number:
ISO:
Whitebalance:
Metering mode:
[TD="class: image-details-value"]79.0 mm (35 mm equivalent: 124.2 mm)[/TD]
[TD="class: image-details-value"]2011-04-02 20:02:40.00[/TD]
[/TD]
third photo
Camera used:
Orientation:
Focal length:
Aperture:
Date/Time:
Exposure time:
Lens F-Number:
ISO:
Whitebalance:
Metering mode:
[TD="class: image-details-value"]2011-04-02 19:27:50.00[/TD]
[/TD]
fourth photo
Camera used:
Orientation:
Focal length:
Aperture:
Date/Time:
Exposure time:
Lens F-Number:
ISO:
Whitebalance:
Metering mode:
with fluro signwriting is there any way of getting it a night without getting it to go like this
Uploaded with ImageShack.us
Camera used:
Orientation:
Focal length:
Aperture:
Date/Time:
Exposure time:
Lens F-Number:
ISO:
Whitebalance:
Metering mode:
[TD="class: image-details-value"]96.0 mm (35 mm equivalent: 151.0 mm)[/TD]
[TD="class: image-details-value"]f/5.0[/TD]
[TD="class: image-details-value"]2011-04-02 19:53:18.00[/TD]
