- Joined
- Mar 24, 2013
- Messages
- 8,796
- Reaction score
- 4,892
- Location
- Connecticut
- Can others edit my Photos
- Photos NOT OK to edit
:lmao:Damn...what is your address?
He lives with me so send it my way and ill make sure he gets it.
I believe the body is made of Magnesium Alloy?, which has a very low rate of corrosion. I don't think you'll have much of an issue, unless you're shooting in sea-spray. Salt increases the rate of corrosion; however, it is still is very resistant to saltwater corrosion. You could always wipe it off after use, or like somebody else suggested, touch-up paint.
you are correct and unless your in constant contact with a corrosive(salt ) it will not be affect , if it is, that will be the least of your worriesI believe the body is made of Magnesium Alloy?, which has a very low rate of corrosion. I don't think you'll have much of an issue, unless you're shooting in sea-spray. Salt increases the rate of corrosion; however, it is still is very resistant to saltwater corrosion. You could always wipe it off after use, or like somebody else suggested, touch-up paint.
