BrentC
- Joined
- Jan 8, 2017
- Messages
- 3,576
- Reaction score
- 2,336
- Location
- Brampton, Ontario
- Can others edit my Photos
- Photos NOT OK to edit
Neat shots. My only nit is the OOF branch in the second one. I think I might have been tempted to clone it out, or find another cat tail to photograph. It is very distracting and IMHO, detracts from an otherwise interesting image.
WesternGuy
We called your " silkweed " plants " milkweed " in Kentucky because of the white milky substance that came out of broken stems. Monarch butterflies love the plant and I could always find their chrysalis hanging from the plants. I like the first photo best because the second is just a bit over exposed for my taste. It is just a matter of likes and taste though. My opinion counts no more than most and much less than the more knowledgeable here.![]()
If you have Photoshop, it can be removed with Content Aware Fill. Trying to remove it in Lightroom is a bit more work. It can be done, just don't try and remove it all at once, but in short bits. That way with the Clone/Heal tool you can reposition the part that is filling in if you have to. If you tried to do it in one piece, it would be almost impossible to find an appropriate match to the whole fuzzy part. Doing it in small bits makes it easier to find a match.Neat shots. My only nit is the OOF branch in the second one. I think I might have been tempted to clone it out, or find another cat tail to photograph. It is very distracting and IMHO, detracts from an otherwise interesting image.
WesternGuy
cattail by Brent Cameron, on FlickrPretty good, but you have outlined one of the problems with the Clone tool in LR. You now have a sharp line in the image that shows up against the background on the right side of the image. Not sure if you cloned or healed, but here is a video that suggest a way to use both with a complex healing problem - http://lightroomkillertips.com/to-clone-or-heal/ . I have to disagree with OGsPhotography, people will notice. Not everyone will know what it is, what caused the "straight" line, but they will notice things that do not seem natural and that is the secret to good cloning and healing - if it looks natural, then it is more likely not to be noticed by the "untrained" observer.
Did you use a single piece to clone this out? If so, you would be better off using shorter pieces and varying the characteristics of the edges so that they are not all linear - make some with slightly curvy edges and maybe combine short pieces with slightly longer pieces - the overall ideas is not to not make any cloning visible to the observer. To do this, you also have to match the cloned bits to a very similar part of the background and this is not always easy to do. Like so many other aspects of post-processing, practice is the only way to get better.
This is a fairly decent job for a first time, but keep on trying as this is one of those processes that takes time to learn and to perfect. Once you get there you will find this a very useful tool for taking out some bits of you image that you don't like (I do it all the time). It is the best way to remove dust spots in you image, where it is necessary to do so.
WesternGuy
