Sky Rail
Sebastian_Riel
Saskatoon; Sask
I'd correct the symmetry in the second one but apart from that, I quite like them, nice clouds.
Yep, the symmetry is a little bit off, but otherwise really good job.
Out of the two pictures, I much prefer the composition of pic 1. Neither picture has any visible blacks. Looking at the histogram, it looks under exposed. Is this the effect you were after?
I did a re-edit on my computer, but as your request, didn't post it. Correcting the exposure, the blacks just popped. Also the sky on the left is darker then on the right side of the bridge. I also did a slight correction to even it out. The Re-edit does look that much stronger.
Thank you :) I'll check it out.
Thank you :)
Thank you :) The sky on the left is darker because the sun is rising on the right. I used custom color channels in my black and white adjustment layer; that's why the blacks are not classically really black. I like how you noticed these details :)
