Taking Pictures of Commercial Planes at night
phkc070408
I have an upcoming plane spotting trip and I'll be in a great area to take on my personal challenge of getting a sharp crystal clear picture of a plane in the sky at night. I'm looking for some advice to achieve this goal.
1. The environment will be on a hotel rooftop with a great view of the glidepath to LAX. I will be no farther than 2,500 feet from the planes, and they will be less than 4,200 feet from touchdown. Aircraft speed will probably never exceed 160mph, most will probably be slower than that. While the sky will be dark, there will be plenty of lights from the city. Also, the aircraft's exterior lights will be on, specifically the tail light that shows off the aircraft's logo.
2. My camera is a Canon R5 Mark ii, full frame. My fastest lens with any kind of zoom is the 70-200mm that has a constant f2.8 as the widest aperture. When focused at the full 200m, I calculate that it will give a coverage width of about 450 feet. The aircraft I'll be shooting will vary in length between 120 feet and 242 feet, so there could be some heavy cropping going on. My next Zoom Lens is the Canon 100-500mm rf which has a much smaller aperture, rated at f4.5 at 100mm, so we're probably looking at a f5.6 or f5.8 at 300mm.
3. Flash - my only flash is a Canon EL-1. While a good flash indeed, I've learned to believe that it won't do much good on a subject that's nearly 1/2 mile away. Bringing stronger flashes or strobes is not an option. Also, I tried using the flash at this location before, but it was extremely humid and we all know how that went.
4. Tripod - I'll have my travel tripod. If I remember correct, my good one won't work there. There's like a bar table around the perimeter of the skydeck and a protective railing that goes higher than my good tripod will extend. I'll have to use my travel tripod with only the neck extended, sitting it on the bar table.
So, onto my thought process for this. No matter what I do, I need to open the aperture up all the way. There's no getting around that. Shutter speed - I'll take a few test shots on scene and see what the slowest shutter speed I can use is. ISO: I'm just going to have to allow some noise in and hope that Adobe Camera Raw's denoise feature will do the trick. The only other option I see is to sacrafice a little light by going with a faster shutter speed and trying to brighten it in post. Thankfully I'll have two evenings on the skydeck and should be able to try both strategies, however I'm more confident in Adobe's ability to denoise rather than brighten a night photo.
Are there any other recommendations to make this challenge successful?
I can't see flash helping at all & I suspect you'll find a monopod more useful than a tripod as you'll wan to pan with the subject
Don't worry about shooting wide open DOF is unlikely to be an issue.
My own night time aviation shots have all been at the evening session of our local airshow, where the planes either have special lighting all down the side, or set of fireworks. I;ve never really been happy with my shots where the planes are generally quite small & somewhat unpredictable in their routes
G'day phkc
As mentioned above, flash will be useless .... after all it's essentially designed for use indoors -or- stuff like parties or weddings.
I would concentrate on
= the 70-200 @ F2,8 to $F4 range - not the big lens
= set ISO to 1600 to 4000 sort of range
= set continuous shooting at say, 2- or 3-FPS (coz the plane's not doing much beyond coming in to land)
= and yes a monopod will be more useful that a tripod coz you'll be swinging yourself thru 180deg as you follow thru the plane's movement
Hope this helps
Phil
Thanks guys. That's kind of what I was expecting, although I don't think the mono-pod will work in this situation. The guard rail around the perimeter of the observation deck is too high. Where there is a ledge, similar to a bar-table near the ledge, and I can put my tripod on that, I'll need to stand on a stool or a chair. I believe my tripod has a built in mono-pod and I can always give it a try.
I have to admit I've never got on with monopods for panning, I find twisting at the waist works better when theirs enough light... A shame because I'd like something to take the weight of my bigger lenses at airshows.
I've never used a mono-pod before. Is it easier to pan smoothly? Occasionally I like to do video as well, and I struggle with panning smoothly.
G'day fellas
2-things here ..... 1)- this thread is about photoing aircraft and 2)- it's now talking about monopods
I am posting a DIY project about monopods into a fresh thread so as to preserve this thread
Phil
I can see a strobe creating a problem, flashing any bright light at a landing aircraft is a great way to get visited by some Federal Agents wanting to know why was that done.
Only if you have a REALLY powerful flash. Even my most powerful studio strobe would not be a problem for a driver at over 500ft and this is likely to be at least three times as far. A laser could be a problem, but no good for lighting the whole plane...
OK, back to my original question - any tips for getting a sharp image in low light situations, outside of bumping up the iso and hoping that Adobe Camera Raw can denoise it?
