The Coffee House
These are E rated 80psi tires. I thought I had 65 in the one that threw the tread but it seems there was more pressure.
Sent from my SAMSUNG-SM-G890A using Tapatalk
That's maximum LOAD pressure (max tire pressure under maximum load). The manufacturer's sticker on the 'B' pillar of the driver's door will give you recommended tire pressure.
This. Many people run far too much air in their tires which leads to premature wear, rough ride, and decreased fuel efficiency.
Always set tire pressure to the reccomended pressure on the B pillar.
. . . Unless you’re on the beach; then air down a bit.
Sox are hanging on by a thread 5-3 bottom 8th. Had to go to Porcello in th 8th to get 2 outs.
Gary is soooo beat. After planting three tomatoes, Gary moved the tiles on the patio. The patio is concrete with these 12”x12” plastic/rubber tiles on top. The tiles are floating on the concrete and are interlocking. Gary disassembled moved then reassembled all the damn tiles. In between moving the tiles Gary was moving furniture and potted plants around. But he finished it all.
Took Gary six hours of continuous work to get it all done. A shower, dinner, vino, Miss Maggie and the Playoffs. Life is good.
Made it to the beach in the afternoon, a bit of rain but the wife went for a swim with the kids. Wore my Astros cap and helped them to a win while swinging in the hammock. Back home and just grated some parmesan for topping the wifes' lasagna and will see if the Dodgers can hold their lead. May have to wear my Rockies cap Sunday and see if they can win one against the Brewers.
Is there a team you don’t like?
34.50 for the week. Messed with more 6 wheelers. If she gets me some new wheels I can get all the 6 wheelers working good.
Going to go by the Post Office and then the box at the front of the neighborhood and then home and give the Mitsubishi a test that tells me if I'm fixing it or dragging it across a scale.
My first little-league team I played on was called the Phillies, but I stopped liking the real Phillies after they beat the Astros in the 1980 NLCS. However, I'm not as bad as my friend from the Dominican Republic, every team that has a player from the DR he calls "my team" (seems like it covers every team in baseball).
The test was inconclusive. I THOUGHT it told me the water pump was bad. Started to take it apart. Find that the water is coming from a weep hole at the main shaft area where I don't think there ought to be water. Don't know where to go from here.
Maybe a crack in the head/block ... ?
Probably. They want 5 bucks and up to talk to a mechanic. I reckon it's terminal.
