The Colloseum (Critique please)
Ankit
Delhi, India
A click of the Colloseum in Rome.
Fine perspective and timing...but exposure a bit problematic ???
Regards :D
Are you talking about the sun peeping out from the side?
That is the plus point; the building is off; i downloaded and made minor adjustments on lighting and i found the result is better.... since you are not OK to edit i don't post... why, yourself can do some processing
Regards :D
Can you please post that photo in the reply. And what software do you use to adjust lighting, photoshop?
I did only some Basic adjustments in Picasa...There is sufficient Photoshopic wisdom here in this forum...and you will get help if you request for the same, i think
So you made the colloseum less dark, looks nice. Thanks.
