This is probably a SUPER noob question, but...
This is exactly why I like to shoot in really cold temperatures. I have found that the colder it is outside, the slower the shutter "response time" and the more flash exposure I can get. It's like your fingers slowing down when they are cold--the dexterity goes and you can't wiggle them quite as fast as when they are hot.
Same thing--the shutter dexterity slows in low temperatures. That's why you see so many snow images overexposed.
So bizarre.
OP, take your camera to the shoot location in a cooler
That's it, I'm designing a portable liquid cooled system for DSLR's.... Gonna keep that shutter icy.
I thought there are issues with lenses exposed to outside air and fast temperature change? Do the lenses not condense, trapping water in the lens?
Might happen if you enter a warm room coming from the cold.
Once my eyebrow froze to the camera at arctic temperatures of minus 40 , that was bad.
:biglaugh:
Never stick your tongue on a cold camera...:mrgreen: :mrgreen: :mrgreen:
Any sufficiently advanced technology is indistinguishable from magic. - Arthur C. Clarke
Condensation happens when going from cold to hot and there is sufficient humidity in the air. So, it's an issue when going from a cool inside to a hot outside, or from a cold outside to a warm inside.
Note: Cold air cannot hold as much moisture as warm air can. Ergo, very cold air at 100% humidity has a lot less moisture in it than very warm air at 100% humidity does.
So condesation is much more likely, and heavier, in the summer than in the winter.
Back in the day, flash sync speeds were on the order of 1/60, because the shutter curtains moved sideways along the long side of a 35 mm frame instead of down the short side of a 35 mm frame like they do today.
Those interested in gainoing an understanding of how the shutter works may want to watch this YouTube video -
Yes, keep your camera in a cooler and then take it out JUST before the shoot :p.
If the shutter speed was dependant on gravity you would never have 1/250s to begin with.
Is this just bull?
Now you are probably wondering; is that guy stupid enough to actually believe it himself, or does he think you are the stupid one?
(cue the Jeopardy music)
