trees
bribrius
its impressionistic.....
The first one is. I think the bright patch on the right is a little distracting, so I'd crop it and then lighten the highlights just a bit.
Cropping on the right would also make the stream lead into the image.
  • Thread Starter 🔹
  • Banned
  • #3
didn't work. I don't see me liking this. feel free to edit yourself. BRI_8740_01.webp
I may be able to when I get home. In any case, I would crop to the right of those two trees that are close together instead of cropping one of them out - it's also better not to have the stream coming exactly out of the corner. I'd also not brighten as much - just a tiny bit from the original.
  • Thread Starter 🔹
  • Banned
  • #5
becoming too much headache for me. I think I am just going to delete it I am not such a fan of it anyway.
It's an interesting shot - here's my take on it just from messing with it for ten minutes.
  • Thread Starter 🔹
  • Banned
  • #7
Looks better than my version! Really only did this because of others doing impressionistic shots. something different. Don't know it is my thing but I do definitely like your version better.
I thought the creek helped this one, I think I got that right.. The creek does look better not in the corner of the frame and I did mess up that crop. You are also right about the light. I cant say you were wrong on anything actually. thanx.
if you don't mind, I might copy your crop and make some adjustments on your advice and maybe I will keep it, with your pemission? Just for a save on the hard drive for future reference most likely.
  • Thread Starter 🔹
  • Banned
  • #9
I don't mind at all. In fact, I will (later) send you a DropBox link so you can have the PS file, that is if you have PS (or at least Elements)? If not, I'll look at it later and just describe what I did.
don't have p.s.. don't need file. Just wanted to use your advice on crop and changes. I generally don't take a photograph as mine anymore once it changes from other input as they have work in it too but wanted to keep it for memory sake. Thanks again.
