Tube extensions and lenses for Kodak Z950?
cbeigle
I am curious. Is there a tube extension and lenses that I can attach to
a Kodak Z950 EasyShare Camera? Thanks.
I am curious. Is there a tube extension and lenses that I can attach to a Kodak Z950 EasyShare Camera? Thanks.
No - the lens is not designed to be removeable.
You can't remove the lens from that camera, but if it will take screw on filters (anadded accessory is sometimes needed for this with point & shoot models) you can add lenses to the front of the existing lens.
Positive diopters (often called close up filters) will make the camera focus closer giving a similar effect to extension tubes.
Wide angle & telephoto converters are also available to screw into filter threads (some of these are dire!)
