two moons...?
rwbanker
Bernalillo, NM
Last night I was taking some shots of the moon as it was rising. When reviewing he shots, there was the moon, but also a reflection of the moon in the picture. I had the camera mounted on a tripod, used a wireless remote, and there was no water to cause a reflection... I used a Nikon D90 with a 55-200 zoom.
Does anyone know what happened and how I can get rid of the extra moon?
Thanks!
Thanks!
Post the pic so we can see it
please excuse the poor focus...
Were you shooting through a window?
nope, i was right smack in the middle of my backyard...
did you have any filters on your lens? i know sometimes indoors i get a reflection if i'm using my UV protection filter i don't know if it could happen outside though
yep, i had a uv filter on the lens... wonder if that is what caused it...
Thnaks for the thought!
Looks like lens flare to me.
You have completely blown out the moon, perhaps not realizing how bright the moon is. It should be considered as bright as the sun. Next time try with an aperture around f/8 and shutter speed around 1/160s. Adjust up and down from there.
I'll give it another try tonight with your suggestions.
What is lens flare?
Flare. It is really interesting with lenses that have bad flare or are multi coated, I have had shots where there are dozens of multi colored moons or suns.
Wow!
Focal Length: 200.0mm (35mm equivalent: 300mm)
Exposure Time: 0.050 s (1/20)
Aperture: f/5.6
ISO equiv: 1600
Cut that ISO WAY down and get that shutterspeed down! You should be able to crop it nice and close also.
I have just a cheap superzoom....
Focal Length: 63.3mm (35mm equivalent: 380mm)
Exposure Time: 0.0010 s (1/1000)
Aperture: f/3.5
ISO Equiv.: 100
I shot this earlier tonight when the moon was ~30° off the horizon. The problem for me with full or nearly full moons is the brightness. I get much better definition when shot in a phase like mrodgers has. (Nice shot BTW :D).
Aperture - f/11
Shutter Speed - 1/320s
ISO - 200
@500mm
So going back to the original question, your UV filter probably caused that to happen. I was taking shots of the city at night and got the reflections not knowing it was the UV filter before coming to TPF. Couple days later I took the same shots w/o the filter and they were much better.
easy: don't use UV filters!
