I think the question amounts to, "Does focal length affect exposure, and do I need to tell the camera what focal length I'm using?"
Focal length is not a camera adjustment; it's a lens adjustment which affects the field of view of the lens. That's the mm number you see with lenses. a larger number mean a narrower field of view which brings a smaller portion of the subject area into "closer" view. In your question, the 35mm prime, the 35 is the focal length. you adjust focal length by zooming a zoom lens, or changing lenses if you have primes. If you have a 35mm prime on the camera, your focal length is 35mm, period. nothing to adjust as far as focal length is concerned, and the camera itself doesn't really care what the focal length is as far as exposure is concerned.
Exposure is determined by the combination of ISO, shutter speed, and aperture, and focal length is irrelevant. Maybe the question is about aperture on different lenses. How can f:2.8 on one lens be the same aperture as f:2.8 on another lens? That's one of the happy things about how lenses work. A 50mm lens with an iris 12.5 mm across passes the same amount of light as a 400mm lens with an iris 100 mm across. If you notice, in the first case 12.5 mm is 1/4 of 50, and in the second case 100 mm is 1/4 of 400mm. In other words, in both cases, the iris size is 1/4 the focal length. If you represent focal length with the letter f, then you can write it as f:4. Does that look familiar? That's the aperture setting for both cases.
That's why focal length is irrelevant as far as exposure is concerned; the aperture setting itself is related to the focal length, and the ratio of aperture to focal length is a constant for light passage in a lens. A longer lens needs a larger iris to pass the same amount of light when compared to a wider-angle lens, but since the aperture setting is that ratio, f:4 on a longer lens is a physically larger iris opening than f:4 on a wide lens, so setting both to f:4 results in the same exposure setting.
If aperture were expressed as a physical opening diameter rather than a ratio to focal length, then things would be considerably more difficult!
